PD-150 sound setup at DVinfo.net
Old July 10th, 2004, 11:53 AM   #1
PD-150 sound setup
Need to be able to use the camera mic as one input, and hook an XLR into the other input. Have found I can get the XLR input in and working if I run it into Input 2, but then can not seem to be able to get the camera mic sound coming into Input 1. Don't have a manual, as I am renting the camera. What settings do I need to have on the camera to make this work?
Sharon Lawler
Visit www.picturethisvideo.net for rates and availability!
Sharon Lawler is offline   Reply With Quote
Old July 10th, 2004, 02:27 PM   #2
The channel 1 switch should be set to channel 1 only and the phantom power should be on.
Check the menu to make certain the sound level controls are in manual and are split.
Mike Rehmus
Mike Rehmus is offline   Reply
