Using LCD to set exposure at DVinfo.net
Old June 29th, 2002, 10:31 AM   #1
I recently taped a variety show. It was only my second outing with the PD-150.
Because the lighting changed quite often, I relied heavily on setting exposure by using the fold out viewscreen.
I also used the Zebra stripe set at 70%.
Much of my resulting footage was too dark. Since it was not all too dark, I am wondering if someone in this group could help me get a better grasp on what I should be doing to get better exposure.
Later today, I will use the camera, a fairly reliable monitor and the viewscreen to recalibrate the brightness of the viewscreen. That should help.
Then I will do tests using the same set up to see what effect the 70% and the 100% Zebra Strip settings have.
Any other pointers will be greatly appreciated.
Roger Lane Glumm
rogerglumm@ameritech.net
1000 S. Holmes Street
Lansing, MI 48912-1924
(517) 485-3609
rogerglumm is offline   Reply With Quote
Old June 29th, 2002, 12:56 PM   #2
Unfortunately, I don't believe you can use the LCD screen to accurately set exposure levels. The monochrome viewfinder is a bit better for this, but, being a LCD itself, is not as good as a conventional viewfinder or monitor.
The zebra stripe at 70% will allow you to set exposure fairly accurately if you have the 'right' type of scene. Caucasian faces (so why don't they have a selection for other skin tones?), green grass and blue sky are all good 70% points.
Faces are always the most important in any scene. So if you have a Caucasian face in the image, you should, coming from the underexposed direction, adjust the aperature/shutterspeed/gain until there is just a bit of zebra in the highlights of the face. Nose, forehead, etc. That should do it.
Green grass and blue sky should also register abut 70%.
I have simultaneously used the zebra pattern and a waveform monitor to observe an image and find the zebra pattern to be most useful and accurate. Not as good as the waveform monitor but OK.
Mike Rehmus
Mike Rehmus is offline   Reply
