Playing Pal/SECAM MiniDV tape on a NTSC Camera at DVinfo.net
Old January 29th, 2004, 03:39 AM   #1
In another forum appears the info that a NTSC VX-2000 camera can play without problems (except the framerate I guess) MiniDV tapes previously recorded in PAL (or SECAM?) system...
Can someone here to test that?.... Any commentary about?
Federico Prieto is offline   Reply With Quote
Old January 29th, 2004, 05:03 AM   #2
Outer Circle
There are only consumer/prosumer NTSC and PAL camcorders, so there is no SECAM miniDV.
Old January 29th, 2004, 09:16 AM   #3
Federico,
The higher end Sony NTSC palmcorders and camcorders will playback PAL footage. I don't know if they will record but they will definately playback as long as you have a multistandard TV.
Adrian Douglas is offline   Reply
