VX-2100 test shots vs PD150 at DVinfo.net
Old December 3rd, 2003, 11:11 PM   #1
http://www.videoproductionbiz.com/videobiznews.html
is the site
Mike Rehmus
Old December 4th, 2003, 12:15 AM   #2
Moderator
Thank you for the heads-up Mike!
+18db? Yikes!
- don
DONALD BERUBE - noisybrain. Productions, LLC
Director Of Photography/ Producer/ Consultant
http://noisybrain.com/donbio.html
CREATE and NETWORK with http://www.bosfcpug.org
and also http://fcpugnetwork.org
Don Berube is offline   Reply With Quote
Old December 4th, 2003, 03:53 AM   #3
Mike, did you compare resolution (spatial and temporal) at +18db. As you know, limiting bandwidth and applying some frame averaging can in combination with coring, drastically reduce subjective noise effects and allow more initial gain, ending up in a brighter image.
Andre De Clercq is offline   Reply With Quote
Old December 4th, 2003, 01:06 PM   #4
Sorry, should have made it clear that it is not my camera nor test.
Mike Rehmus
Old December 9th, 2003, 08:53 PM   #5
So, I take it that the PD-170 will have the same results as the Vx2100 shown above?
Frederic Segard is offline   Reply
