PD150/VX2000 Picture Distortion at DVinfo.net
Old April 18th, 2002, 11:01 AM   #1
marina***
Posts: n/a
Watching the signal output from the PD150 to an external monitor, I noticed that the face of the subject appeared somewhat elongated. 16x9 was definitely turned off. We then tried pointing the camera at a perfectly round object - it appeared elongated in the middle of the screen. At the edges of the screen there was another type of distortion: at screen left, the circle looked "squashed", this time horizontally; same happened at the bottom of the screen, as well as the top (not as pronounced); whereas at screen right it looked more elongated again.
Checked the picture on a different monitor - same result.
Checked both at wide and telefoto: pretty much the same distortion, although not as pronounced at the wide end. It gets most noticeable somewhere in between wide and telefoto, it seems.
We also have a VX2000, and immediately checked it as well (although I never noticed this problem with it before), - same results!
I am still hoping that perhaps the monitors are causing this (as these are regular commercial TV sets) - but maybe not? It would be so sad if the optics on these cameras (even on the PD150!) had a problem.
I should note that both of these cameras are PAL. So are the TV monitors.
Has anyone else experienced this problem?
Could anyone test it out, with a round object, to see if you get any distortion?
Thanks very much.
Old April 18th, 2002, 11:11 AM   #2
marina***
Posts: n/a
P.S. The LCD screen on the camera doesn't show the distortion - but then again, it's hard to tell on such a small screen.
