How can I check hours of usage? - Page 5 at DVinfo.net
Old September 9th, 2005, 08:46 PM   #61
Thank you.
Eric Stemen is offline   Reply With Quote
Old January 27th, 2006, 06:11 PM   #62
sony vx2100 have hours meter?
i can't remember if the vx2100 has an hours meter measuring its use
i know the pd150/pd170 does.
can anyone point me to which screen w/in the menu would allow me access to the hours menu?
thanks in advance
be well
rob katz
harvest film
Rob Katz is offline   Reply With Quote
Old January 27th, 2006, 06:32 PM   #63
No, there isn't a menu item for that on the VX-2000 or 2100. However there is a way to find out if you want to spend a few bucks; get an RM-95. See the following:
http://www.dvinfo.net/conf/showthread.php?p=181342
Old April 20th, 2006, 09:18 AM   #64
Help reading camera hours on pd150
Can someone explain what all this stuff means on a pd150.
Operation 41x10h, Drum 18x10h, Tape 10x10h, and threading 72x10h,
tayproductions
Derek Grimes is offline   Reply With Quote
Old April 20th, 2006, 05:01 PM   #65
operation is how long the camera has been on.
drum is how many times round the drum has run.
tape is how many hours have been recorded.
and i think threading has something to do with how many times the tape has been ejected.. but im not 100% sure on that one.
Joe Lawry is offline   Reply With Quote
Old April 20th, 2006, 05:09 PM   #66
Reading Camera Lingo
Thanks Joe! I thought that was what the operation and tape were but not sure about the others...Now, this may sound stupid but does the " X 10" literally mean "times ten"
In other words, does 41 X 10 mean 410 hours?
tayproductions
Old April 20th, 2006, 05:36 PM   #67
yes - X 10
Leslie Wand is offline   Reply With Quote
Old August 9th, 2006, 09:05 PM   #68
please help with hours?quickly
is this alot of hours or not?
i dont really understand the x10 thing. is it just multiply by 10 or what
Hour meter:
operation: 30x10
drum: 19x10
tape 10x10
threading: 57x10
thanks for looking and helping
by the way it is a pd150 if that matters
Nate Fields is offline   Reply With Quote
Old August 9th, 2006, 09:10 PM   #69
help with hours please? quickly
Hour meter:
operation: 30x10
drum: 19x10
tape 10x10
threading: 57x10
dont really understand the whole x10 thing
thanks
Old August 9th, 2006, 09:35 PM   #70
Those numbers except the threading numbers get multipied by 10 as you surmised. those are very low numbers for a PD150 and, in general, low numbers for any camera.
Mike Rehmus
Old August 10th, 2006, 05:52 PM   #71
anyone that can help please
Old August 10th, 2006, 05:59 PM   #72
Hi Nate and welcome to DVinfo. I suspect you haven't gotten a response since the thread title was "help with ours" instead of "help with hours" :-) Also, it would help if you give a clue as to what sort of camera you're asking about.
I'm assuming it's probably a PD150/PD170 so I'm moving this thread to the correct forum. But this question comes up a lot so have a look at some of these threads, which our "search" function turned up:
http://www.dvinfo.net/conf/showthread.php?t=65523
http://www.dvinfo.net/conf/showthread.php?t=36625
http://www.dvinfo.net/conf/showthread.php?t=29843
http://www.dvinfo.net/conf/showthread.php?t=28263
http://www.dvinfo.net/conf/showthread.php?t=10959
Old August 10th, 2006, 07:28 PM   #73
thanks so much
Old August 10th, 2006, 10:28 PM   #74
i hope to get the pd150 but i am in the air for a gl2 also.
i had a gl1 and liked it but it seemed too old.
Old August 11th, 2006, 05:17 AM   #75
frankly I would go with the 150 not just because I'm a Sony kind of guy but look at the features of the 2 cameras.
The 150 has bigger chips than the GL2, it has superior low light capabilities over the GL2, it has easier and more control over the image than the GL2. Other than that, I guess they're pretty close ;-)
Go for the Sony, I think you'll be very happy with it.
Don
Don Bloom is offline   Reply
