Is the PD 150 "TRUE" progressive scan? at DVinfo.net
Old September 11th, 2003, 09:13 AM   #1
Is the PD 150 TRUE progressive scan or pseudo progressive scan like the Canon XL1s?
Hugh DiMauro is offline   Reply With Quote
Old September 11th, 2003, 09:24 AM   #2
Guess you need to define 'true.'
Mike Rehmus
Old September 11th, 2003, 10:12 AM   #3
PD150 has true prog scan in terms of capturing a full frame at the time (so, not the green blending story like Canon does), BUT it only refreshes 15 (12.5 for PAL) times/sec.. so it's a 15p concept. It keeps full vertical resolution as long as the shutter is set at 1/60 (1/50) or faster.
Andre De Clercq is offline   Reply With Quote
Old September 11th, 2003, 01:23 PM   #4
Thank you so much. I guess, then, the AG DVX is a true 30p?
Old September 11th, 2003, 10:22 PM   #5
Barry Wan Kenobi
The DVX100 is true 30P and true 24P. The PD150 has true 15P.
Barry Green is offline   Reply
