Used cameras what/how to test ? at DVinfo.net
Old September 1st, 2003, 07:52 PM   #1
Hello everyone, learning many new things because of this forum.
Considering purchase of used pd150 or vx1000 from online auctions where I can test the camera before I accept it. How do you test and what do you test for in a used camera over 3 days ?. Also, can an extended warranty be purchased by new camera owner?
Thanks in advance
Jose Marrero is offline   Reply With Quote
Old September 2nd, 2003, 09:19 AM   #2
The camera checkout subject was covered in this forum not too long ago I think. Do a search. Otherwise, test everything that is covered in the manual and do a lot of shooting.
I don't believe anyone will write an extended warranty for a used camera unless it is a warranty from a specific store for a camera sold by them. Armatos is one that comes to mind.
Try to avoid the VX-1000. Just too old, hard to get repaired and very expensive to repair. Not nearly the camera as the VX-2000 or PD150.
Mike Rehmus
Old September 3rd, 2003, 08:37 AM   #3
Go Cycle
Testing a Used Camera
1) Look for external marks, dents etc.
2) Check for DEAD PIXELS-place lens cap over the lens and increase the gain/db's. If you see white spots then you may have a bad ccd block.
3) Listen to the tape transport system. If you hear a loud buzzing then a lower head drum assembly may be needed-a common problem with the camera.
4) Actually look at the recorded tape. If there is excessive digital break-up or a venitian blind type "look" you may need a good cleaning or even worse-new heads.
5) Ask for the ORIGINAL box and bill of sale from the seller. The camera could be a third or fourth hand camera.
6) Lastly, make sure that the lens has a protective filter. Look for MOLD, scratches etc. on the original lens. Make sure that the battery is included as well as ALL accessories.
Lou Bruno
Lou Bruno is offline   Reply
