Sony VX2000/Canon WD58 Lens Question at DVinfo.net
Old August 5th, 2003, 06:07 PM   #1
Hello all,
Question I have is :
Is it ok to put a screw-on filter between the camera and the Wide Angle lens?
Thank you,
Steve
Steve Montoto is offline   Reply With Quote
Old August 5th, 2003, 06:33 PM   #2
Outer Circle
That's not wise. It places the adaptor further away from the lens. Perhaps try it first, and see if you get distortion and/or vignetting.
Some wide angle adaptors come with filter threads up front. But you usually still get vignetting. A "mat box" is one solution.
Old August 5th, 2003, 09:20 PM   #3
Also, by sandwiching the filter, there is a lot more stress on those threads from the weight of the lens.
"DOH"!!!
Harry Settle is offline   Reply With Quote
Old August 5th, 2003, 11:07 PM   #4
Also, pay attention to the orientation of the WA-58H lens hood. Once, I had rotated the hood and caused a blackened triangle in the upper left hand corner of my footage.
Gints Klimanis is offline   Reply With Quote
Old August 6th, 2003, 05:41 AM   #5
I shot a boat cruise with a circular polarizer behind the WD58. Having earlier learned about the hood's orientation issue I had constantly to make sure I was zoomed enough to get past it, given that the hood was rotating along with the polarizer! But I do love the look of the result, in bright sunshine on endless water. Having said that I'd love a matte box but without bionic arms my hand-held days would be over. This (http://www.contentshop.tv/newcam.htm) is what I'm lugging around as it is.
David Hurdon
David Hurdon is offline   Reply
