VX2100 didt record?!?!?! at DVinfo.net
Old July 20th, 2008, 03:26 AM   #1
I was shooting yesterday, and today i want to capture my footage but its not on the damn tape :|!!!! How did this happen:S?!??!?!
Ruwan Heggelman is offline   Reply With Quote
Old July 20th, 2008, 04:45 AM   #2
did you hit the record button? Was the tape in protection mode (record protect tab slid on) Did you see the REC in the LCD or VF, was the time code running? If these things were going on then it's got to be there UNLESS you placed the camera on a subwoofer case with a 15" speaker and the magnet erased the tape. Don't laugh. It's happened. Perhaps you grabbed the wrong tape to load and it's not really the tape you shot on?
If the REC lifght was showing and or the time code was running and the tape protction was not on and you hit the REC button AND didn't erase the tape then it has to be there.
Don
BTW, my sister in law and brother in law live in Dordchect (sp) Say 'HI' to them for me ;-)
Don
Old July 20th, 2008, 04:53 AM   #3
everything was working; rec was on screen, timecode was running.
its so irritating strange :S!
i will say hi xD!
Old July 20th, 2008, 05:04 AM   #4
Did you change the tape at the end of shooting? Maybe you put it somewhere "safe". I'd say go over every tape you can find in the kit you used yesterday.
Also do a test to confirm your cam is working. Just record a couple of minutes and capture. If that fails as well, you may have a defective camera.
George/
P.S. Don, I have some friends around Chicago. Say hi to them when you see 'm!
George Kroonder is offline   Reply With Quote
Old July 20th, 2008, 05:05 AM   #5
see post under
Old July 20th, 2008, 05:10 AM   #6
ok i have found the beginning xD i miss the middle and the end of it :| wtf
Old July 20th, 2008, 05:15 AM   #7
I only once heard about someone with a vx2100 recording for 10 minutes with nothing on the tape, in that case it was a tape that had been used several times, it still contained the recording made before but nothing from the last recording.
Did you use a used or unused tape?
Old July 20th, 2008, 05:17 AM   #8
used it a couple of times yes.. i found the beginning (2 minutes)
Old July 20th, 2008, 05:20 AM   #9
I have no explanation why this could occur but think the risk of errors increases when using a tape more then once.
I actually never re-use a tape and suggest if you want to minimize the risk you should do the same, you also might consider running a cleaning tape before you do any other recording.
Old July 20th, 2008, 05:33 AM   #10
Shit..... :S..
