Internal Battery on PD150 at DVinfo.net
Old February 26th, 2008, 12:45 PM   #1
I found the manual online and on page 157 it said to plug the camera in for 24 hours. I did what it said, however the internal battery is not holding a charge.
Does anyone know the location in the camera to get at it to change it, and can it be changed -- or is it hard wired in? The manual is of course silent on tech stuff.
HELP!!!!
Chuck Volm is offline   Reply With Quote
Old February 26th, 2008, 02:16 PM   #2
If memory serves from an earlier thread on this issue, I think it's a factory job only -- the battery is hidden in a board secured behind a panel on the side of the camera and is designed not to be user-replaceable.
Old February 26th, 2008, 03:09 PM   #3
Ouch! -- sounds expensive. any ideas where I could send it -- some trusted place?
Old February 26th, 2008, 04:02 PM   #4
Aside from Sony, the name you hear most often is Armato's, in NJ.
Old February 26th, 2008, 04:03 PM   #5
Armatos in NYC is probably one of the best. But camera owners have done this themselves. IIRC, it is in a battery holder, not soldered in place.
Do a search
Mike Rehmus
Old March 1st, 2008, 11:28 AM   #6
I'm pretty sure this page shows the exploded view of the top handle where the cells are stored. They last about 4 to 5 years and then need to be replaced.
http://www2.sonysupport.com/PF/POV04...pperhandle.PDF
Shouldn't be too difficult to dismantle it. Girls put them together, so boys can take them apart I say.
tom.
Old April 6th, 2008, 05:40 AM   #7
Armatos was the answer!
As a final note to this thread, I sent it to Armatos and for around $200, they cleaned, lubed, adjusted, and changed the internal battey. I'd say they are the best!
