VX & PD series battery / batteries - Page 11 at DVinfo.net
Old February 7th, 2005, 11:09 AM   #151
There is one thing about this camera I'm not at all happy with, the eyecup. It is very thin, flimsy and collapses backwards if I pull the camera into my eye like I like to. It drives me nuts and is virtually useless for my style of shooting. I'm already looking for another one but am not seeing much available.
At full draw,
Tyge Floyd
Tyge Floyd is offline   Reply With Quote
Old February 7th, 2005, 03:33 PM   #152
<<<-- Originally posted by Tyge Floyd : There is one thing about this camera I'm not at all happy with, the eyecup. It is very thin, flimsy and collapses backwards if I pull the camera into my eye like I like to. It drives me nuts and is virtually useless for my style of shooting. I'm already looking for another one but am not seeing much available. -->>>
Try the I-CUFFDV viewfinder hood. EVS has them.
http://www.evsonline.com/merchant2/merchant.mvc?Screen=PROD&Store_Code=EVS&Product_Code=ICUFFDV
Jim Garrison is offline   Reply With Quote
Old February 8th, 2005, 01:13 PM   #153
Battery and Hum
Tyge:
The hum is an LCD flipout door malfunction that Sony (I believe) will repair. B & H may take it back.
I purchased an aftermarket 13 hour battery at B & H for $59.00. Just for regular shooting it goes for about ten to twelve hours. Not bad.
Interesting, if true. And interesting anyway.
Hugh DiMauro is offline   Reply With Quote
Old February 10th, 2005, 03:30 AM   #154
i have 3x960s, i don't think even one of them has ever run out on me during a shoot! they're great. the best thing about a camera at this level is you can get batteries that long that are cheap, small and last a long time. upgrade to a bigger cam, and you'll soon realise the pain batteries can be :)
and yes, the recording channels mode is very odd when you first use it, and makes little logical sense.. but when it "clicks" you realise just how good an idea it is.
James Connors is offline   Reply With Quote
Old February 11th, 2005, 04:17 AM   #155
Sounds to me as if you're describing barrel distortion rather than vignetting, Bob. (Canon WD58). If it really is vignetting (darkening the corners of the frame) then make sure you remove any filters before fitting the Canin w/angle.
tom.
Old February 11th, 2005, 08:11 AM   #156
Thanks Tom,
You're right...I meant barrel distortion, not vignetting.
Bob
Bob Harotunian is offline   Reply With Quote
Old June 27th, 2005, 06:26 AM   #157
battery or PD170 problem? help!
When I turn on my PD170, the battery power remaining shows something around 145 minutes. In less than one minute, it´s almost empty. It jumps from 145 minutes to that "almost no battery" sign, and then turns off.
When I attach the battery to the recharger, it shows around "2h47m" of battery life.
What might be causing it? If it´s a battery problem, do you think the better is solution is thinking about buying another one?
Almost forgot: this battery (Li-ion 5500ah~7.2V - NP-F960 from a brand called ENERGIA) has being used for about 8 or 9 months.
lml
Gustavo Godinho is offline   Reply With Quote
Old June 27th, 2005, 09:41 AM   #158
It sounds like the battery blew a cell. Either return it if you have a manufacturers warranty and get a new replacement battery or go out and buy a new replacement. Batteries do occasionally blow cells and when that happens you can't fix it.
Don
Old June 27th, 2005, 04:39 PM   #159
Don, you mean my battery won´t work beyond those 147 minutes?
lml
Old June 27th, 2005, 07:02 PM   #160
No, I mean you're battery won't work for more than a few minutes if that. Once a battery blows a cell the battery is not going to hold a charge at all and will give false readings. This has happened to me once with another brand of battery for my 150s. You need to replace that battery with a new one.
Don
Old July 8th, 2005, 04:34 PM   #161
Fred Retread
Battery charging indication on the 2100
I just got mine out of the box an hour ago. Checking charging progress is going to be a hassle. It seems that I have to unplug the charger, fire up the cam and wait for it to sense the charge level. Am I missing anything?
"Nothing in the world can take the place of persistence..." - Calvin Coolidge
"My brain is wired to want to know how other things are wired." - Me
David Ennis is offline   Reply With Quote
Old July 8th, 2005, 06:53 PM   #162
When you first charge a battery or one that has been discharged down to the camera shutoff level, you may have to leave it in the charge mode for several minutes, before any number of recording minutes appears on the display. After that, the growing number of minutes should show, without having to disconnect and start the camera.
I almost never use the in-camera charger, preferring to use my $45. Sima SPM-13 L-ion fast charger. It's twice as fast as the built-in charger and doesn't tie-up the camera when you want to shoot or do playback with it. It works with most brands and models of 3.6V and 7.2V lithium batteries.
Steve McDonald
Steve McDonald is offline   Reply With Quote
Old July 8th, 2005, 07:22 PM   #163
Fred Retread
Steve, I would ultimately buy the charger, but I do want things to work as they should. Are you saying that an indication should appear in the display even though the cam is turned off? That's what the manual implies too, but neither it nor you said that explicitly.
I get no charge level indication unless the cam is on and the adaptor cable is unplugged even with a battery that is 70% charged.
Old July 8th, 2005, 07:49 PM   #164
Fred, I just plugged in my VX2100 to make sure. The small LED battery display on the outside of the viewscreen door does indeed light up when the camera is off and the external DC power plug is in and a battery is inserted. It shows the number of recording minutes in the accumulating charge. I installed an NP-F570 that was previously charged and in the time I've typed this, it's gone from 212 to 214 minutes.
I recommend that when the charge gets close to the maximum possible charge, that you stop the charging. When it's near full capacity, the charging rate will slow to a crawl and it
will take 10 minutes to add just one more minute on the meter. It may not be good for the battery to ram that extra little bit into it and it certainly isn't time-efficient.
Steve McDonald
Old July 8th, 2005, 07:57 PM   #165
Fred Retread
Steve, thanks for you patience. I didn't notice that that window was there, I thought the "display" references were to the LCD or viewfinder.
