VX-2100 Audio at DVinfo.net
Old September 8th, 2007, 05:26 PM   #1
VX-2100 Audio
Can anyone tell me what the difference is between 16 and 12 bit audio for the VX-2100 and what should I use? Thanks.
Ron
Ron Anderson is offline   Reply With Quote
Old September 8th, 2007, 06:19 PM   #2
Always use 16 bit. 12 bit makes music sound bad and doesn't do too much for voice either.
If you use 12 bit, you can get 4 channels of sound on the tape but channels 3 & 4 are strictly for use after you have recorded the video and the first two channels of sound. Don't bother.
Mike Rehmus
Old September 12th, 2007, 10:26 AM   #3
Would it be possible that the 12 bit setting could make the audio playback sound distorted when going through a DJ's system? I used a 50ft cable with rca jacks from my camera to the DJ's audio equipment and it was a disaster. The audio was extremely hot and distorted. I listened to the tape before the event on my home stereo system and didn't pickup anything like this. Could it have been the connection. He was up on stage, so I could not see if he adapted to a 1/8 mini plug or not. Any experience with something like this?
Ron
Old September 12th, 2007, 05:17 PM   #4
I record live bands and i only use the camera audio as a source to synch up my useable audio (in post) i recorded seperately with my audio recorder(in my case a Sony HiMD)
For high quality audio i beleive most use a dedicated audio recording device.
Did you send the cable to the line in or mic in?
Manual or Automatic Gain Control?
Jim Sobolewski is offline   Reply
