help with 2100 at DVinfo.net
Old August 22nd, 2007, 04:48 PM   #1
help with 2100
ok pros little help please , #1 what do i need ? i shoot a film transfer it to lap top burn it to dvd with windows movie maker and yes its not clear and crisp like it is when play it back on the camera and yes im cheap to many hobbies what do i need ?? #2 to help protect lens ( i have a hood on it) would i filter help too and which one works with a hood ? #3 good but low end wireless mic s ?? ''go easy on the cheap guy'' thanks ron sony dcr-vx2100
Ron McCorkell is offline   Reply With Quote
Old August 22nd, 2007, 07:39 PM   #2
1. Search through this thread for ideas, suggestions, and answers.
http://www.dvinfo.net/conf/forumdisplay.php?f=37
Personally, I use Sony Vegas and DVD Architect.
2. Get a decent, inexpensive [under $10] UV or Haze filter (58mm) to screw onto the front of the camera. This will protect the camera's lens. If you scratch or break the "cheap" lens, it's no big deal to replace.
3. I have a couple of Audio Technica 88w wireless sets that work fine for me. The cost for each complete set (transmitter, receiver, lapel mic) is about $100 brand new. Whether it's a good choice for you depends on your application and where you plan to use it. There is limited range (about 30+ feet) and it can be affected by interference.
Good luck...
Jeff
Jeff Emery is offline   Reply With Quote
Old August 24th, 2007, 09:13 PM   #3
thanks
thank you i need all the help i can get ;i shoot deer videos and im trying to up grade quality
