PDX10... next step down? at DVinfo.net
Go Back   DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony TRV950 / PDX10 Companion
...plus TRV900, PD100A and other Sony DV camcorders.
Old May 20th, 2003, 07:26 AM   #1
Hi, I'm looking to buy a prosumer cam for filmmaking purposes... I really like the PDX10, but it's just a little too expensive... can anyone tell me a camcorder similar to it for a few hundred dollars less?
The things I like about the PDX10 are:
- it's high pixel rate CCDs
- ability to shoot in DVCAM mode
- the fact that 16:9 and 4:3 are both the same quality with it
- 1 megapixel for shooting still pictures
thanks! :)
Graham Kolbeins is offline   Reply With Quote
Old May 20th, 2003, 07:35 AM   #2
Re: PDX10... next step down?
<<<-- Originally posted by Graham Kolbeins : The things I like about the PDX10 are: - ability to shoot in DVCAM mode -->>>
AFAIK the PDX-10 is the least expensive model in the DVCAM line. You might find that the Panasonic DV-953 can do some of these other things, although I've never seen one. I imagine Frank will chime in on this though... :-)
Old May 20th, 2003, 01:55 PM   #3
Outer Circle
Yeah, I would say go for the PV-DV953, then. Cheaper, good 16:9, high resolution, great color, good audio. However, you'll need good lighting, audio should be improved with an XLR adaptor/external mic, and no DVCAM---miniDV should be good enough---they're both the same resolution.
Frank Granovski is offline   Reply
  You are here: DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony TRV950 / PDX10 Companion
