Handle at DVinfo.net
Go Back   DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony TRV950 / PDX10 Companion
...plus TRV900, PD100A and other Sony DV camcorders.
Old March 3rd, 2003, 11:27 PM   #1
Handle
Can you add a handle on the top of the 950? If so how can this be done?
Zach Breton is offline   Reply With Quote
Old March 4th, 2003, 02:26 PM   #2
Not that it would not get in the way of the pop up light.
I did run across this interesting tidbit here. A side handle so to speak that holds the mic away from the cam and can be set up in several ways. It is called the mini-mount and here is the link for it.
http://www.videosmith.com/
KennJ
Kenn Jolemore is offline   Reply
  You are here: DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony TRV950 / PDX10 Companion
