PDX10 and Progressive Aspect Ratio at DVinfo.net
Go Back   DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony TRV950 / PDX10 Companion
...plus TRV900, PD100A and other Sony DV camcorders.
Old February 24th, 2003, 08:14 PM   #1
I was wondering if the progressive mode on the PDX10 (using the photo mode through the 1394 port) shoots in 16:9 or 4:3. Anyone know?
Glenn Gipson is offline   Reply With Quote
Old March 1st, 2003, 06:23 AM   #2
Outer Circle
I don't know, but once in photo mode, are you able to switch to 16:9 mode?
Old March 1st, 2003, 09:10 AM   #3
Photo mode leaves you stuck in 4:3 but you get all the pixels working when running to a hard drive so you are getting alot more information than normal record mode.
KennJ
Kenn Jolemore is offline   Reply With Quote
Old March 1st, 2003, 03:28 PM   #4
Outer Circle
Thanks Kenn.
Old March 2nd, 2003, 06:41 AM   #5
Thanks.
Old March 21st, 2003, 02:42 PM   #6
Recording in photo mode
Frank,
You mention using this in photo mode with a hard drive...do you mean doing a live capture via Firewire? If so, how many pixels are being used?
Brandt Wilson is offline   Reply With Quote
Old March 22nd, 2003, 05:42 AM   #7
It's the same as in Photo mode.
http://www.techshop.net/PDX-10/
KennJ
  You are here: DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony TRV950 / PDX10 Companion
