Newbie 16:9 Question (fcp w/ pdx10) at DVinfo.net
Go Back   DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony TRV950 / PDX10 Companion
...plus TRV900, PD100A and other Sony DV camcorders.
Old March 20th, 2006, 03:09 PM   #1
i've been reading and learning about the pdx10's widescreen...and if i'm correct, it retains it's resolution in 16:9 mode, instead of blowing up the image horizontally or chopping it vertically.
so if this is true, what i'm wondering is this: could i shoot and edit in 16:9 mode, and then before output, use the "Aspect Ratio" slider in the "Distort" menu of the the "Motion" tab to shrink the video vertically (-33.3%) to correct the aspect ratio, and therefore shrinking the vertical pixels and creating a sharper-higher-quality image? does this make any sense?
Jonathan Downs is offline   Reply With Quote
Old March 20th, 2006, 03:58 PM   #2
You don't want to do that...
If your final destination is DVD, the DVD player will automatically squash the 16X9 video for display on 4:3 sets...giving you the "increase in vertical sharpness" you are talking about.
John C. Chu is offline   Reply With Quote
Old March 20th, 2006, 04:03 PM   #3
ahhh...so the dvd player does the aspect ratio correction by itself. i get it now...so if the dvd is viewed on a 16:9 television, it will fill the frame...but if it's viewed on a normal 4:3, it will be automatically be squished down and be letterboxed. i get it.
thanks for the response.
Old March 23rd, 2006, 03:13 AM   #4
Worth doing a test using your camera settings, using your editing programme, using your DVD authoring set-up, your DVD burner, playing it in your DVD player into yout TV. Nothing like testing before the big day.
tom.
Old March 25th, 2006, 04:56 PM   #5
Almost, but DVD players should give two options for 16x9 material on a 4:3 display. One is as above ("letterbox"), but the other fills the entire 4:3 frame of the display with the centre of the widescreen image - this is known as "centre cut". In practice letterboxing will lose resolution, not increase it - the DVD player will reduce the 576 (480 for NTSC) lines vertically down to 432 (360) - then add 144 (120) lines of black to regain the standard PAL (NTSC) signal.
Much material is now produced 16:9, but 4:3 safe - nothing vital, especially captions, graphics etc, happens outside the centre 4:3 area of the frame.
David Heath is offline   Reply
  You are here: DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony TRV950 / PDX10 Companion
