PDX10 capture problems at DVinfo.net
Go Back   DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony TRV950 / PDX10 Companion
...plus TRV900, PD100A and other Sony DV camcorders.
Old September 14th, 2005, 07:57 AM   #1
hey i was wondering
i have a pdx10 i play my recorded tapes through a jvc brdv3000u deck i usually capture with avid, pinnacle or ulead
when i have simple stuff to do i use ulead to do a quick dvd
when i capture footage shot on my pdx10 using lavelair for recording the sound
i dont get all the audioi get a kinda mon0 mix
any help here will be greatly appreciated
also what software do u guys use for captureing etc
Damien Greaves is offline   Reply With Quote
Old September 14th, 2005, 12:01 PM   #2
Known Problem with X10
This is a stupid problemn with the X10 that sony will NOT own up to... The only way I've found to work around this is to buy "scenalyzer" With this you can also capture in Type 2 AVI's with a better codec and not compress to microsoft AVI until you have to... This is the only way I can see to get around the problem. The software is also cheap... Hope this helps...
http://www.scenalyzer.com/
Craig Bellaire
www.VerticalVideoSolutions.com
Craig Bellaire is offline   Reply With Quote
Old September 14th, 2005, 12:32 PM   #3
Well I'm not sure whether you're properly placing the blame on Sony. Audio works properly in FCP on the Mac without any special drivers or software. To me that would imply a problem with the Windows firewire drivers, but of course I really don't know for sure.
But the problem has been discussed here at length. See the following threads:
http://www.dvinfo.net/conf/showthread.php?t=17454
http://www.dvinfo.net/conf/showthrea...threadid=25252
http://www.dvinfo.net/conf/showthrea...threadid=26190
http://www.dvinfo.net/conf/showthrea...&threadid=7958
http://www.dvinfo.net/conf/showthread.php?t=44362
http://www.dvinfo.net/conf/showthread.php?t=47541
Old September 14th, 2005, 12:32 PM   #4
Maybe the PDX10 wrote to the tape in DVCam format and the JVC is designed to play back only the MiniDV format?
Try playing it back directly from the PDX10 and see what happens.
Dean Sensui
Old September 14th, 2005, 05:59 PM   #5
hmmm
thanks boyd for all the info
after reading the posts i feel tired
i realise i can capture fine in avid but not everyday for small projects i feel to use it
right now i go from my jvc to my pyro av link to my cpu
i never used to get dropout now i get it and for some stange reason my pyro goes into strange colors after capturing for a while
thank god for the this user group cause i really thought it was my fault
thanks fellas for all ur help
Old September 14th, 2005, 10:03 PM   #6
Hi,
What is the different between Type 1 and 2 avi's? Which one should I use with Premier 6?
Ronald Lee is offline   Reply With Quote
Old January 11th, 2006, 05:55 AM   #7
soft for pc
so wich editor softwere works well with pdx10 in a pc??
Claudio Fernandez is offline   Reply With Quote
Old January 12th, 2006, 07:12 AM   #8
Claudio, I use Adobe Premier Pro and am very happy with it. I capture my footage using Scenlyzer, just because it's a bit simpler and I am accustomed to it.
Hope that helps--
Chris
Chris Long is offline   Reply With Quote
Old January 12th, 2006, 07:25 AM   #9
Which Software
hey happy new year to everyone
regarding your question to which sotware works well
i have all types of editing software i am like a jack of all trades
ulead mspro8 wont capture the audio properly
i have also tried premiere and it didnt (think is 6.5 though)
Avid dv 4.5 and avid pro does work with it properly
what i do to capture to progams that give trouble with the audio ifrom the pdx10 is
from my deck jvc brdv3000u i use the s video and left and right audio which are rca to a canon zr40 or analog to digital converter e.g. canopus or ads then use the firewire from the converter to my cpu
actually i added a audio mixer between the jvc deck and the converter so i adjust audio on the fly is kinda primative but it works
but other than that problem the video and audio is great from this camcorder
oh i did try the scenalyzer software it worked great but i still have to get myself a copy
NOTE WHEN I SAY IT DIDNT WORK I DONT MEAN THE EDITNG SOFTWARE DIDNT WORK ALL OF THESE EDITING PACKGES WORKED FINE THE PROBLEM IS THE CAPTUREING OF AUDIO IN THAT MIXED MONO MODE WHERE U CANT SEPARATE CHANNEL 1 FROM CHANNEL 2
Old January 12th, 2006, 12:44 PM   #10
thanks
well thanks so much Damien and Chris i going to tray new things
  You are here: DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony TRV950 / PDX10 Companion
