PDX10 image vs. PD150/170, DVX100... - Page 2 at DVinfo.net
Go Back   DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony TRV950 / PDX10 Companion
...plus TRV900, PD100A and other Sony DV camcorders.
Old September 8th, 2005, 01:15 PM   #16
See the following:
http://www.dvinfo.net/conf/showthread.php?t=49944
Old September 8th, 2005, 01:28 PM   #17
Got it!
Boyd, thanx much. You are such a great source for those of us who are still treading in the shallow end...:)
rd
Ramdas Lamb is offline   Reply With Quote
Old September 30th, 2005, 05:46 PM   #18
Is there any truth to the rumor that the PDX10 and Panasonic GS400 use the same CCDs?
The GS400 also has 1/4.7" megapixel CCDs that allow for hi-res 16:9 via 4:3 shaped chips. Are these two cams using the same chips? And if so, would that mean that you could match footage between these cams?
Brian Andrews is offline   Reply With Quote
Old September 30th, 2005, 09:09 PM   #19
You'd be hard pressed to find a difference.
Stephen Finton is offline   Reply With Quote
Old October 1st, 2005, 10:08 AM   #20
I would take a shot at saying that Sony and Matsushita are knuckle-2-knuckle in the ring and there'd be no way that they'd share the same chip supplier. They both buy in different lenses (Leica and Zeiss) and these have different multi-coatings that influence the final colours to some degree.
Matching footage between cameras is probably easier in post these days - double click white balance filters mean you can tell the computer what should be white in both shots, and the pc will do the matching for you.
tom.
Old October 1st, 2005, 10:45 PM   #21
tom.
Really? What programs? Particulary, what programs can I use on my PC laptop?
Ronald Lee is offline   Reply With Quote
Old October 1st, 2005, 10:53 PM   #22
I have this facility on my Canopus Storm 2 capture card, and I assume others have the same facility as well. It's a life saver for any wedding videographer, as 99% of brides wear white, and with key-frameable white balance I can track her as she walks room to room and even outside.
tom.
  You are here: DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony TRV950 / PDX10 Companion
