Any other way to change... at DVinfo.net
Go Back   DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony TRV950 / PDX10 Companion
...plus TRV900, PD100A and other Sony DV camcorders.
Old June 12th, 2005, 10:11 AM   #1
from record mode to vcr mode without using the main switchy thing?
I dropped my camera and it just stopped working, and I got the error E:61:3 or something like that. I banged it really hard and it started working again, although the main switch for changing modes is still broken. I can only record. Any suggestions?
Daniel Hoyland is offline   Reply With Quote
Old June 13th, 2005, 03:19 AM   #2
RED Code Chef
Hello Daniel. Even if there was another way, would you really want to?
1. you dropped the camera and it broke
-- it should have been repaired or replaced at this point --
2. you intentionally banged the camera, braking it even futher
-- that was something you really should not have done, it is quite feasible you just made the repair a lot more expensive --
The camera should be serviced / repaired. If that is too expensive (versus
a new camera, I have no idea what this particular camera costs new) you
should get a new one.
Why? Because even if you do get it to work the camera is unreliable. More
can (and probably will) break and this will no doubt happen at a time you
do not want it to happen. Better make sure you get the problems sorted
before you do any serious shooting with it.
Good luck!
Rob Lohman, visuar@iname.com
Rob Lohman is offline   Reply
  You are here: DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony TRV950 / PDX10 Companion
