Last call for PC350 at DVinfo.net
Go Back   DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony TRV950 / PDX10 Companion
...plus TRV900, PD100A and other Sony DV camcorders.
Old March 18th, 2005, 05:08 PM   #1
Last call for PC350
Last chance to get your PC350
http://www.ecat.sony.co.jp/tourist/videocamera/products/index.cfm?PD=17707&KM=DCR-PC350E(JE)&LG=1
replaced by the HC90, which has the distinct disadvantage of not recording the full width of the 1/3" CCD in 16:9 mode but alas is cheaper
John Jay
Beware ***PLUGGER-BYTES***
John Jay is offline   Reply With Quote
Old March 19th, 2005, 12:38 PM   #2
Hey John - curious why you say the hc90 doesn't record 16:9 the same as the 350 ? It says in the specs 2050k pixels for video and I've read from another poster in another forum that it's the same . The hc90 ( ntsc version ) also does true 30p instead of the bad 24p of the 350 which really interested me more since I'm in that world . Iwas still toying with the idea of the pal350 as a second or third camera when the specs for the hc90 came out along with a good hands-on in another forum. Also the 16:9 lcd is very cool and it's cheaper. take care Kurth
Kurth Bousman is offline   Reply With Quote
Old March 19th, 2005, 02:39 PM   #3
in 4:3 video mode both cams spec a 35mm equivalent of 45mm at the wide end of things
however in 16:9 the HC90 is a miserly 42.8mm - around 5% wider
the PC350 gate crashes at 37.5mm which is almost the full width of the 1/3" chip (37mm) (I have measured it)
It is for this reason why the HC90 can only be considered 1/4" cam for 16:9 video
if this is no importance to you get the HC90
John Jay
Old March 19th, 2005, 03:33 PM   #4
John - can't this simply be a focal length issue difference between the two lenses and not how much of the chip is receiving said image ? I think I see what you're saying - if both @ 4/3 are the same focal length using the full chip then the relative usage @16:9 would lead you to expect similar results. I'm fairly ignorant about optical theory but doesn't the distance from the chip to the lens affect this combination of events? thanks Kurth
Old March 20th, 2005, 01:53 PM   #5
whichever way you look at it
37.5mm plays 42.8mm for an assumed identical zoom of 5.1-51mm
John Jay
  You are here: DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony TRV950 / PDX10 Companion
