Thread Tools
Search this Thread
#31 |
Outer Circle
#32 | |
I think this is what recall. Probably not very helpful, as people have reported elsewhere that the RM-95 is no longer listed on Sony's site.
#33 |
TRV900 or PDX10?
If you could choose between a TRV900 or a PDX10 what would you pick? Given the PDX10 has better 16x9 and the TRV900 has better low light capabilities. I'm looking for something to travel with and don't want to use my PD170 since its a little big. I like the fact that you can take off the XLR connector on the PDX10 and it looks basically like a TRV900/950. Suggestions?
#34 |
Outer Circle
My opinion, the TRV900---if you don't mind lower resolution, no XLRs and no superior widescreen.
#35 |
Frank,
Why is it that you prefer the 900 over the PDX10? Any specific reason? |
#36 |
There is a comparison of the 900 and 950 at Bealecorner which you might find interesting. Of course the 950 doesn't have the XLR block, BW viewfiinder, DVCAM recording or high res 16:9 mode of the PDX-10.
The 900 is getting somewhat old now so you will also need to consider the life expectancy of a used camera vs a new one. |
#37 |
Boyd,
I understand your point. The 900, as I understand, has better low light capabilities (4 lux) vs. the 950/PDX10 (7 lux). Would this make a big difference in real world situations? Also the 900 takes the "L" series Lithium batteries that my 170 takes so I wouldn't have to invest in different batteries that the 950/PDX10 takes "M" series. I already have a 900 but was thinking about upgrading and either selling it or giving it away to a family member. I love the PDX10's capabilities but am wondering if I'd be giving up too much for the different batteries and low light capabilities. |
#38 |
Contributor
> and either selling it or giving it away to a family member. > I love the PDX10's capabilities but am wondering if I'd be > giving up too much for the different batteries and > low light capabilities. I adore my PDX10, but before buying it I suggest you check out the new Panny '30.
Ignacio Rodríguez in the third world. @micronauta on Twitter. Main hardware: brain, eyes, hands. |
#39 | |
Outer Circle
#40 |
I also adore my PDX10, both of them, in fact, and think that it would make a fine replacement/upgrade to your 900, as well as a complement to your 170, as it is for mine. Beyond your traveling, you will have another cam with good sound and sound inputs, and the 16:9 is fantastic to have around. You will, however, be giving up some of the manual control that you have with your 900.
Breakthrough In Grey Room |
#41 |
Shawn,
What manual controls would I be giving up? I would think that the PDX10 would be more of a pro camera vs. the 900 and would have more manual features. Also I read some problems with audio capturing with the PDX10. I'm using a Mac and Final Cut Express so am I going to have this problem? |
#42 |
I also use Mac and FCE, and have no problems capturing audio.
I'm not especially familiar with the 900, but doesn't it have independent NDs and independent gain control? The PDX has neither of these, although it seems to be officially true that it has undocumented and automatic internal NDs. There are a couple of major threads around here about this. The PDX has an "exposure" control, WB, independent audio channel controls, a heap of shutterspeeds, and the same custom presets and auto/focus/lock switch and button in the front that the PD170 has.
#43 |
It's more of a pro's holiday cam. Perhaps Sony sought to keep the cost of it down, and also have it not threaten PD150 sales? Peculiar omissions, perhaps, but a brilliant little cam nevertheless.
#44 | |
<<<-- Originally posted by Paul Chun : Also I read some problems with audio capturing with the PDX10. I'm using a Mac and Final Cut Express -->>>
Paul, you should be fine in the audio department. The problem seems to be related to the firewire drivers and NLE software on some versions of Windows. Shawn, I haven't seen a 900 either but I'm willing to bet that exposure control is pretty much the same as the PDX-10, which is also the same as my VX-2000. From bealecorner Quote:
#45 |
Tweaking a TRV 900
Are there any tweaks or tools out there so you can change factory settings on these cams.
In specific, I need to use auto focus a lot. I shoot a lot of hand held, close, fast moving stuff. Is there a way to speed up the factory set auto focus motor? Am I insane....or are there cameras out there that have naturally fast focus. Paul |
