Battery for DSR-PDX10P at DVinfo.net
Go Back   DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony TRV950 / PDX10 Companion
...plus TRV900, PD100A and other Sony DV camcorders.
Old December 11th, 2004, 11:36 AM   #1
Hello everybody,
We will soon buy a PDX10P and we would like to know if there any hopes... that the Sony battery NP-FM91 is working for the PDX10P because I used them on my small TRV-30 ??
Thank in advance for any answer.
Pierre
ex-XL1, TRV30E, XL-2 & PDX10
Pierre Vetsch is offline   Reply With Quote
Old December 11th, 2004, 02:25 PM   #2
I am not familiar with the FM91 personally, but the PDX-10 manual says that it will work. I have an NP-QM91 and an NP-QM91D for my PDX-10, the only difference being that the 91D has LED's that show the charge level. The QM-91 gives me about 4 hours continuous run time with the LCD screen open and phantom power to the mike. The manual indicates that the FM91 should give comparable results.
Old December 12th, 2004, 12:11 AM   #3
I have several batteries.
I have a QM70 and bought a replacement, turned out to be the FM70 - works perfect. FM91 is only bigger. I also had a TRV-30e,
all my batteries worked in the PDX10P. Had to replace my TRV30 due to an encounter with a submarine (long story - http://www.dvinfo.net/conf/showthread.php?s=&threadid=23494)
So glad I did.
I'm sure you'll love the PDX10P as much as I.
Chris Thiele is offline   Reply With Quote
Old December 12th, 2004, 04:44 PM   #4
battery, submarine & volcanoes...
Good news for me, Thank you Boyd & Chris. So I can use the same batteries, really happy to know that.
Chris: Tasmania very far off !!! Well encounter with submarine should be an very impressive event. In addition your story make rising in me a stange feeling. I'm passionated by volcanoes and try film them. I was an happy owner of one XL-1 since almost six years but last october on Mount Etna in Italy I lost all my stuff except the TRV30 !! I was on a steep slope and just finished to film very nice lava channel and was few meters from my bag looking for the eyes (for the pleasure) when there was a big rising in the rate of emission of lava, provocating a break from lava tube just above me and ... my stuff. I have just the time to quickly go aways but without the bag !! Hard end for my Xl-1, engulfed in lava...
Anyways thank to time to answer me
All the best
Pierre
Old December 14th, 2004, 09:47 AM   #5
Pierre, that's quite a story! Glad that the only thing you lost was your camera.
Old December 14th, 2004, 03:21 PM   #6
Yes you have right and I don't feel very proud because I largely underestimate the risk but I was alone and nobody was hurt.
The lesson (at least) for me was that I need in this kind of areas a more compact camecorder, so I can keep it easier on my back.
I hope that the PDX10 will be the right stuff!
All the best
Pierre
Old December 14th, 2004, 03:50 PM   #7
If you want to "run light" with the PDX-10 then remove the XLR block and mike - the camera will still record stereo sound through its builtin mikes. They include a neck strap with the camera. You can easily hike around all day with it on the strap and hardly even realize it's there.
  You are here: DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony TRV950 / PDX10 Companion
