Since the Z1 doesn't have progressive , what about ... at DVinfo.net
Go Back   DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony TRV950 / PDX10 Companion
...plus TRV900, PD100A and other Sony DV camcorders.
Old November 11th, 2004, 12:19 PM   #1
A more detailed discussion of the alluded real 25p on the pc 350e. I could never downloaded John Jays' footage. Did anyone look at his footage and is it real p ? It appears this question has been just out of reach on the internet. I've read a number of posters on other forums that leave questions about the prog function and never receive answers. Who can step up to the plate ? thanks- Kurth
Kurth Bousman is offline   Reply With Quote
Old November 11th, 2004, 02:22 PM   #2
If you want to badger CH for space on his ftp I can up it there
John Jay
Beware ***PLUGGER-BYTES***
John Jay is offline   Reply With Quote
Old November 11th, 2004, 06:27 PM   #3
John , I was hoping to hear from you again. What's your updated opinion. I've been reading your posts in SM's forum(HDV) and it sounds like you know more than I, so I'd love to hear more. How does it do in fast pans in cinema ? , does the lack of audio monitoring really hurt ?, What % resolution gain would I hopefully see over a typical ntsc considering it's prog and pal ?, at the moment I can't remember if it's got stablization in cinema mode ?, how's the autoexposure ? Have you projected it ? etc.,etc. (just a few questions !) I love it's size faqctor, it's lancability and int.hotshoe. Is it worth the $350 higher price it commands over the 350 ? Is the centuryoptics .65wa 37mm the best, & what have you learned about wa adapter suitability ?
Next calling CH . I'd love to see it over my computer , thanks for the offer , I'll see if I can reach out , but also I trust intelligent opinions. thanks Kurth
Old November 12th, 2004, 07:56 AM   #4
<<<-- Originally posted by Kurth Bousman :
it performs like a 16:9 25p camera should
audio can be monitored at the line out, no pain no gain
I believe the ratio is 576/480 = 1.2 times more vertical resolution
Yes it has
Works fine
No
In Japan there was no price difference between country specific variants
I use a (pre Super 8) Canon C8 0.65x WA with thin step rings. This is an outstanding afocal lens adapter with 4 elements and multicoated. Its the silver alu one from the early sixties and weighs as much as the camera. In 35mm terms I am getting about 24mm wide :)
Next calling CH .
Good Luck!
John Jay
Old November 15th, 2004, 03:48 PM   #5
thanks John - I thought that a progressive image had about a perceived 40% higher resolution than a interlaced image if you keep it progressive and output on a progressive display ? That's the number I always heard tossed about. Besides the film-out capabilities , that's the advantage of a progressive image - the full res is always present- is that incorrect ?
I believe this makes the 350e , along with the DVX and XL2 , the only SD cameras under 5k , to have a progressive image. How would you say it would stack up , considering the overall pixel count is not that different ?
Have you done any enhancements to the image in post , like filmlooks ?
You gave me an idea to pull out my c-8 super 8 wa for my canon 1014xls and try it on my pd100a and it works real nice at full wide giving me just the right barrel distortion- I'd thought of using video wa adapters on super 8 cameras but the reverse hadn't occurred to me . thanks- Kurth
  You are here: DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony TRV950 / PDX10 Companion
