January 12th, 2005, 12:53 AM | #166 |
Thanks guys for the reviews.
Ignacio, it was reading your review that helped sway me to buy the PDX10p. I had read several reviews that came straight from the Sony manual, yours was, as you put it "I am not a professional videographer or video engineer..." thanks Ignacio. Oh, and I am glad I bought it too ;) |
January 12th, 2005, 02:35 AM | #167 |
Yes, I've written to Steve Mullen about the mistakes in the review. But I was pleased to see his conclusions were the same as mine with this cam - if you leave it to its own devices (ie leave it in auto) then it does a mighty fine job. Trouble is pros should never leave a cam in auto...
tom. |
January 29th, 2005, 02:06 AM | #168 |
PDX10 focus issue
My PDX10 in autofocus mode, seems to lose focus while I zoom in or out at any speed. It takes longer to correct the focus when zooming at higher speeds, but it is still very noticeable at even the slowest zoom. It snaps back into focus as soon as I release the zoom rocker.
I also tried manually focusing around 10x, then slowly zooming out wide. While I did not get a blob as described in a previous post, the image is completely out of focus (not just soft). I tried resetting the camcorder to make sure it wasn't being caused by some setting I had made. No change. Any ideas? Could my backfocus need adjustment? Does anyone know what Sony charges for adjustments and cleaning? Thanks. |
January 29th, 2005, 09:17 AM | #169 |
BJ, see the following thread which discusses a similar problem: http://www.dvinfo.net/conf/showthrea...threadid=35310
It is possible that there's a problem with your camera... is it out of warranty? Contact info for service centers may be found here http://bssc.sel.sony.com/Professiona...cecenters.html |
February 3rd, 2005, 06:59 AM | #170 |
Custom Settings on PDX10P
hi all,
does anyone change the settings in the Custom Preset menu on the PDX10? What changes do you make generally? I was thinking of keeping all the settings standard except for bumping up the colour by 2 notches. Anyone experienced anyone problems when doing this? |
February 3rd, 2005, 07:23 AM | #171 |
Does everyone like their coffee black? I was thinking of adding a little sugar, has anyone experienced problems with this? ;-)
Well of course the custom presets are there to let you tune the image to your taste, and after getting used to the camera just about everyone will experiment a little and make adjustments depending on the circumstances. We've discussed this a lot here in the past. Here are a few threads: http://www.dvinfo.net/conf/showthrea...threadid=16952 http://www.dvinfo.net/conf/showthrea...threadid=19812 http://www.dvinfo.net/conf/showthrea...threadid=16186 |
February 9th, 2005, 06:07 PM | #172 |
PDX10 eject problem
Hi all, I just registered to look for help with this problem:
When I open the door to tape eject, the tape carrier mechanism rises up (as normal), but then the tape holder does not pop out. Instead, nothing happens for a couple of seconds, then the mechanism goes back down. There is no tape in the camera. This started happening a few days ago. There is no error code, and the camera otherwise operates normally. Although I live in a humid climate, this does not fit the symptoms of a condensation problem, as far as I can tell. Also, I have experienced this problem once before, several months ago. However, at that time, it went away after a few hours and did not recur until now. Anybody else had this problem? |
February 9th, 2005, 08:45 PM | #173 |
Sorry, haven't seen that one although I can recall maybe once or twice when I opened the outer door and the inner one didn't open. The standard response would be to tell you to push the camera's reset button. If this doesn't help then it may be service time....
February 10th, 2005, 05:31 PM | #174 |
Thanks for the tip, but resetting didn't fix the problem.
Any other ideas? I'm borrowing someone else's camera for now, but I really don't want to take my cam in for servicing for something that SEEMS so simple. |
February 15th, 2005, 08:49 AM | #175 |
Slow Motion with PDX10P
Hi all,
Whats the best way to get a decent quality slow motion from the PDX10P (PAL model), in regards to shutter speed, software to use, etc etc... |
February 15th, 2005, 09:54 AM | #176 |
I don't think the issues would be any different on the PDX-10 than any other interlaced camera. Use our search feature and you'll find extensive discussion on this topic. My personal opinion is that you should leave your shutter at 1/50 which gives the optimum amount of samples. Using your NLE software you should then be able to slow the captured clip down as desired. In FCP there is a "frame blending" option which general helps smooth things out; I imagine other programs have something similar. There is something called "Twixtor" which others report good results with, but I've never used it myself.
February 17th, 2005, 06:58 PM | #177 |
PDX10 Hours
Hi all,
I checked the hours of use for my camera, and would like to know if this is considered light use, moderate use or heavy use?? I may be selling this camera in the not so distant future.. and want to be able to give an accurate assesment of the Cameras condition.. Here are the hours operation 14 x 10 hours drum run 4 x 10 hours tape run 2x10 hours threading 19 x 10 hours Thanks, Mike Moncrief |
March 2nd, 2005, 08:35 PM | #178 |
Which platform is most compatible with the PDX10?
I'm interested in hearing your experiences with the PDX10's compatibility with Macs and PCs. I've just bought the PDX10, and I've used both Macs and PCs in the past. Personally, I perfer PCs, but I've also heard mention of audio problems with PCs and the PDX10. I'd certainly be willing to go Mac if it is the most compatible platform. Any suggestions on what I need to consider?
Thanks, Chris Nelson |
March 2nd, 2005, 08:57 PM | #179 |
I gather there are some problems with stereo sound when capturing via firewire on the PC. There are workarounds however. See the following:
http://www.dvinfo.net/conf/showthrea...threadid=25252 http://www.dvinfo.net/conf/showthrea...threadid=17454 http://www.dvinfo.net/conf/showthrea...threadid=26190 http://www.dvinfo.net/conf/showthrea...&threadid=7958 I can report however that FCP on the Mac doesn't have any of these problems. Other than this, it really shouldn't matter which platform you use. The PDX-10 shoots standard DV-25 and should be compatible with all the popular NLE's. Pick the hardware and software you're most comfortable with personally. |
March 7th, 2005, 07:24 PM | #180 |
PDX10 vs. Final Cut Pro: round 9678769
Ok,
Great camera, great quality, great everything. However, I can not capture footage from the tapes I used in my pdx10 to final cut...when i try i get an error telling me i havent set the capture bins, but i have. what in the world is going on? I have tried capturing the tapes, onto my computer, with another camera but i get the same error. I tried capturing old tapes from other cameras through the PDX10, and i had no problems. Has any one else had this problem? What in the world? I am about to go crazy... If any one knows what to do i would really appreciate it. I have footage on this tape that is irrespaceable and I need it for a project I am currently working on. I could dub the tape but I would rather figure this problem out now rather than suffer for years to come. I have been tryign to figure this out in several fincal cut pro forums but its been a few days and still no progress. So, i thought maybe other pdx10 users may have run into this problem as well. Let me know... ANY and all help would be appreciated, Thanks, Nevin
That'll do pig, that'll do |
