#91 |
Hi Boyd / Steve
Yep I think (if i may say so !) Boyd misquoted me slightly ther. what i actually said about the HC1000 / HC1 was that when you fix the shutter speed and then change the exposure manually (which of course you can do), you can't for all EV values, change ONLY aperture or ONLY the gain. It may well be in, say, middling light levels that when you change the exposure down, that the camera will be at 0db gain anyway, and so will just close the lens 1 stop, so yep that's in effect direct control of the aperture and the shutter speed BUT if light levels fall, say, and you manually increase exposure then you get to a point where the camera is at max.aperture and will have to go to +3dB gain. so that's the limitation really. - It does have 'shutter priority' mode (to draw a 35mm phrasing analogy) but it wouldve been nice if Sony had given us 'aperture priority' mode too, independent of gain. Quite why on the A1 Sony still haven't given the user the aperture, gain in-LCD during shooting i don't know. I can see their 'product positioning' guys saying "Oh HC1 is consumer camera so let's not give them that feature" but omitting it for A1 is a bit odd. Having said that i love my HC1000 to bits - it's a great camera and very similar, functionally, to the HC1 (which i'm getting as soon as i get back to a PAL country !) rgds |
#92 | |
#93 |
The time has come....
UPDATE:
Have put samples on web page in order to illustrate problem... http://www.sonic.net/~stepnext/SAMPLES/indexSO.html The magnified version is very very very magnified...and does not appear that large in image. _______ Here are current conclusions/observations/theories BACKGROUND 1. The problem did appear in second camera. 2. I did find ways to limit it (but not eliminate) (decreasing sharpness while shooting/blurring in postproduction/) 3. I believe (not sure) that the problem is more common than reported. At least I believe that the same problem was described in an archive here. I just found it this week...after returning first camera. __________________ http://www.dvinfo.net/conf/archive/i...hp/t-3382.html SOMEONE ELSE's ENTRY ABOUT SONY 950: "I examined my tape in full, both on the camcorder viewing screen and on my TV and found that the 30 minutes of tape I had shot were filled with vertical bands, white or multicolored, which I later learned were the vertical smear problem" ________________ 4. But I also have come to believe it doesn't ultimately cause difficulty for most production goals. (It doesn't appear in most mediums...such as computer monitor, VHS dub.) 5. I just contacted a local television station....because that's the final destination of my current project. The representative said he's very familiar with the problem and has found it doesn't cause problems with airing on our local TV stations. (Our standards are lower than many larger areas.) He also told me it's common in most prosumer cameras and is eliminated in higher end cameras (which I can't afford). Though, I'm currently researching to find out if some other similarly priced cameras do not have problem. All of these problems did get me thinking that the GS400 may have been a better choice. DECISIONS...DECISIONS...THE TIME HAS COME... Tomorrow is the last day to decide (based on exchange policy of seller). I could be wrong...it could be that I got two bad cameras..and should try to exchange this one...or even get the GS400...if that's possible. But I'm inclined to conclude it's time to accept that all cameras have limitations...and the SONY HC1000 while limited in this way...will meet goals for which it was purchased. In separate entry (below), include reasons why I suspect it's a common problem...and how to mitigate it...for those interested. PS. I freely admit I have a lot to learn. Plus, I was limited in my ability to try out the camera. In order to qualify for exchange...I was limited to 120 minutes of use with camera...and time limit of one week. So, I'm sure I have not examine every aspect...considered EVERY angle. So, my decision...is based on best understanding...to date. And...I realize someone on forum might offer a different perspective that would be good to consider before making final decision. Though one big limitation is funds. At this point, I can't afford a more expensive camera. So, that's not an option. THANKS in advance for taking time to respond. |
#94 |
BELOW IS BACKGROUND which I believe helps to explain why digital camcorders have trouble with lines (light lines against dark background).
And...it's what led me to believe problem is common. FROM: PREMIERE for MACINTOSH & WINDOWS by Antony Bolante "Graphic elements that look good on a progressive scan monitor display poorly on an interlaced monitor. Due to interlacing, thin horizontal lines (or patterns containing thin horizontals) appear to flicker or vibrate. If a line is thin enough, it actually disappears with every scan of its field." [NOTE: I suspect that the spiralling colors results when the "line" disappears. But that's a guess.] (Sandra) Anthony Bolante...continued... "Avoid using light typefaces, thin lines, and tight patterns in images that are destined for television. If necessary, choose the Flicker Removal option in the Field Options dialog box." '"Flicker Removal" blurs the image so that thin horizontal details don't flicker due to interlacing." _________________ NOTE: I found it takes more than "flicker removal." I needed to use "blur" from "video effects". There are varous ones--to apply. It's a trial and error process. The first time I tried the "blur" effect, it didn't seem to work. But the "Quick Time" blur effect worked. And then others like "fast blur" helped. Yet, while the "blur" effect seems to eliminate the blur...it also diminishes sharpness/quality of image. ALSO...decreasing "sharpen" feature in camera helps...when shooting. Last edited by Sandra Warshaw; August 11th, 2005 at 04:02 AM. |
#95 |
I don't know Sandra, I just can't see much of a problem in those examples, although the first camera seems to exhibit it more. It would be good to know what all the camera settings were. Did you shoot in full auto mode? Did you change any of the custom presets? Try viewing the data code (should be accessed via touch screen buttons) while playing the tape. It will tell you the aperture, shutter speed, etc. Also, as you note, the sharpness setting could be an issue. Go to custom preset (I assume this camera has them?) and I would suggest turning the sharpness all the way to the minimum, it should give you a nicer image that way, or at least it does on my PDX-10.
I don't really see any of these problems on my PDX-10 which uses the same chips and sensors. BTW, I think B&H sells the HC-1000 for $1,400 and the PDX-10 for $1,600 (with rebate). If you can exchange I think the additional $200 would be very well spent considering all the additional features it has. But I don't think the problem is related to vertical smear at all. That would only happen on bright white areas in extreme conditions. Also, since you only see the problem on your TV screen... how is the camera connected to the TV? Are you using the composite (RCA) jacks? That's a very poor quality connection and shouldn't be a basis for quality decisions. Can your friend at the TV station hook the camera up or play the tape on a good monitor? Sorry, you've got me stumped here! |
#96 |
You wouldn't be talking to us at all, if you had a progressive scan camera. :)
#97 | |||
THIS FORUM IS A REAL LIFE-SAVER!!!!!!!!!!!!!!
SHORT VERSION Quote:
Posting my concerns here...helped me reach a decision...I know I could not have reached without this GREAT input. I am returning the HC1000. I am now SERIOUSLY considering the PDX10. Thanks for telling me about the rebate. That makes the PDX-10 an option. They are currently out of stock...at B&H...but said they expect to get them in week (although the price has gone up.) Today, I've been reading about it in reviews (here and elsewhere) and in online articles. Sounds very very promising. In many ways! For example, the XLR adaptor will actually save me money...since my current XLR adaptor is not compatible with the HC1000 And that great review on this forum by Ignacio Rodríguez de Rementería... and that article http://www.ukriversguidebook.co.uk/maranon.htm about a freelance videographer who who used a PDX-10 to film a South African expedition down the Amazon River in Peru...certainly demonstrate its many strengths...while documenting its limitations...realistically. LONGER VERSION...CONCERNING OTHER QUESTIONS As to your questions about settings...I tried all variations that I'm aware of...and they failed to deliver a satisfactory image. Quote:
From what you're saying...and others have written...I believe the PDX-10 will be a MUCH better match for my use/goals. ******************************* THANKS AGAIN!!!!! for taking time to seriously consider concerns and offer solid, practical solutions. |
#98 |
Nice having something in common with you Sandra...if only for a little while. :(
#99 |
Just wondering how the HC1000 would compare to a GL2 on the video quality side of things?
#100 |
It will shoot much better 16:9 because of its high resolution CCD's. No frame movie mode though.
#101 |
Boyd's right in answering your specific question; the 1000 is a much newer design than the GL series.
But if you'd asked us both, "which camera is the better machine?" I bet we'd both have come up with a different answer. tom. |
#102 |
Hmm... I am not much of an HC-1000 fan if that's what you're implying. The tiny battery and elimination of physical manual controls put it pretty low on my list. The manual controls on the GL-2 are going to make it more attractive.
I'm sure you can produce great results with either of these cameras though, since the camera itself is only part of the equation. But honestly, neither of these cameras would make my short list today... |
#103 |
I honestly like not having the buttons on the outside of the camera. It forces me to setup my shot ahead of time and not ride the settings while I video. I know this sounds like a cop-out but I have had video shot by people who were just helping us using cameras other than the HC1000 and they wouldn't leave the damn exposure alone. We just shot a little independent film a couple of months ago and I set the cameras and forgot it. I did have one person switch it to auto focus but we had no scenes that required any movement in the foreground, so everything was just right when we went to edit everything together.
#104 |
Still Loving My HC1000s!
I have not experienced the image problems mentioned here about them. In fact I've dropped one and it still works perfectly, although I do not suggest you try dropping them.
I REALLY don't know what camcorderinfo.com was going on about in their "review" of the camera. They prove that they didn't even REALLY review the camcorder because the reviewer said that it's swivel design does not lend to low level shooting. In fact, they say it points at the sky. Check it out, though: http://img.photobucket.com/albums/v3...e/DSC00108.jpg |
#105 | |
The page you are requesting cannot be found |
