Telephoto at DVinfo.net
Go Back   DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony TRV950 / PDX10 Companion
...plus TRV900, PD100A and other Sony DV camcorders.
Old May 11th, 2004, 10:35 AM   #1
Telephoto
I have TRV 950, and I would like to take a shot focus on 1 object and the background is blur. Does anyone know how to do it? Do I need Telephoto len to do that? if so, which model you suggest? Thanks
Angela Chan is offline   Reply With Quote
Old May 11th, 2004, 06:46 PM   #2
If your object is small and close, you can always use macro mode...there is portrait mode in program AE, which widely opens apeture also helps blur the background...tele does help though, but I don't think it's common to use a tele just for shallow DOF purpose...
Chan from TW or HK I guess?
Love Mov is offline   Reply With Quote
Old May 11th, 2004, 10:17 PM   #3
If you zoom in all the way and use manual mode with the iris wide open then you should be able to get this effect, here's an example http://www.greenmist.com/trovatore/f...909/leonora/04. Sure, adding a telephoto adaptor will help even more. Sony makes a 2x "high grade telephoto" that I use and it's great, although not cheap.
Old May 12th, 2004, 09:41 AM   #4
Thanks.. let me try your technique... (Chan from HK)
  You are here: DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony TRV950 / PDX10 Companion
