moiré effect on pdx/trv950 at DVinfo.net
Go Back   DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony TRV950 / PDX10 Companion
...plus TRV900, PD100A and other Sony DV camcorders.
Old April 23rd, 2004, 07:03 PM   #1
The worst thing I don't like my older camcorder is the moiré effect, (jaggle line or grid lines in some pattern when paning)..well, not sure what's exactly the name should be, I hope you know what I am saying...
Home video looks bad because of this, never see such effect on a DVD, although the resolution are the same, leave me wonder if the problem is DV format itself or camera.
Any thoughts?
Love Mov is offline   Reply With Quote
Old April 23rd, 2004, 09:58 PM   #2
Contributor
Yes. Minimize edge enhancment and your PDX10 should be much better in this sense (softer jaggies) than your average DV camera because of the higher resolution of it's CCD array.
Ignacio Rodríguez in the third world. @micronauta on Twitter. Main hardware: brain, eyes, hands.
Ignacio Rodriguez is offline   Reply With Quote
Old April 23rd, 2004, 11:06 PM   #3
So, you mean lower the sharpness? Or other parameters?
Thanks.
Old April 23rd, 2004, 11:39 PM   #4
Precisely. Having lowered Sharpness to it's minimum several months ago and for good, my attention is rarely drawn to jaggies anymore.
Breakthrough In Grey Room
Shawn Mielke is offline   Reply With Quote
Old April 24th, 2004, 03:17 AM   #5
Shawn and Ignacio are correct. Lowering the sharpness down to its lowest setting will eliminate the Moire that I can see in the TRV-950 when S-video to the TV.
However, you don't see this in DVD outcomes because, as far as I can tell, all AVI to MPEG2 converters use a low pass filter on the video during rendering. I am not sure about the high end like Canopus (too much money for me) where you may be able to turn off or customize the low pass nature of the conversion.
Anyway, for Pinnacle I noticed that, in lowish light, frame grabs from the DVD compared to the AVI were significantly lower noise and signficantly softer (but look better). This is indirect indication of the lowpass filter effect (and why Moire is absent in the Pinnacle rendered outcome). I ran a series of experiments with my cam sharpening, then rendered to find the best settings POST RENDERING.
At the moment, I set the TRV-950 down one notch during capture for sharpening. Pinnacle low pass then softens it a bit more and boom, sharp enough outcomes, low noise and no Moire.
So, when setting the sharpness setting you may want to do it as a system experiment in conjunction with your rendering platform.
It is a good thing you see Moire though. This is the equivalent of aliasing of high frequency components. Meaning.....the TRV-950 and PDX-10 appear to have a higher resolution than NTSC video....not a bad thing.
New to Video but Learning Fast.
Sony TRV-950
Canon ES-970
Canon Elan
Canon AE-1
Canon Z-135
Yashica Mat124G
Mike Sanchez is offline   Reply With Quote
Old April 26th, 2004, 06:15 PM   #6
Contributor
Hmm... but I thought the downsampling process in itself should act as a good LPF... thus most moire must come from the sharpening algorithm. It has been commented on several threads that the PDX10's lowest 'sharpness' setting seems to be the most natural setting. So like Shawn I have kept it at minimum.
Still, it makes a lot of sense to check your final output when looking for the ideal settings, for this and other parameters. I guess it's not easy to get a TV station to output a siginal from your camera while you tweak the setting though, which is what I would have to do since most of my current work is for a TV program :S
Anyway I will try now setting it to a little higher than minimum and see what it comes out like when broadcast.
Way to go, Mike!
Old April 28th, 2004, 01:52 AM   #7
Ignacio,
Thank you and you must be correct that the downsampling procedure would remove frequencies above NTSC. Pretty much has to I guess, by definition. So, the sharpening must be the cuprit and, since the Moire goes completely away at minimum sharpening when my cam goes direct to TV this is another indicator that it is just the sharpening.
Don't see why a big TV station cannot broadcast your experiment to all of us.....I'm in!
Sony TRV-950
Canon ES-970
Canon Elan
Canon AE-1
Canon Z-135
Yashica Mat124G
Old April 28th, 2004, 09:46 AM   #8
Contributor
Jajja, I am pretty far away in a hidden corner of the world so it would have to be a really big big TV network for that to happen. Now if by chance know of a vacancy at the local branch of CNN... <grin>
  You are here: DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony TRV950 / PDX10 Companion
