Lens "cap" for the large sun shade? at DVinfo.net
Go Back   DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony TRV950 / PDX10 Companion
...plus TRV900, PD100A and other Sony DV camcorders.
Old April 15th, 2004, 01:24 PM   #1
I want to leave the large shade on all the time. What is everyone else using for a lens cap for these hoods?
Sean
‘I don’t know what I’m doing, and I’m shooting on D.V.’
- my hero - David Lynch
http://www.DeepBlueEdit.com
Sean McHenry is offline   Reply With Quote
Old April 15th, 2004, 04:53 PM   #2
I had a Sony TRV30 video camera, killed it, but found that its smaller lens cap fits in the large hood. That's what I am using.
Chris Thiele is offline   Reply With Quote
Old April 15th, 2004, 05:29 PM   #3
Outer Circle
That's what I use as well: the original lens cap inside the hood.
Old April 15th, 2004, 05:48 PM   #4
Frank, what I mean is that I don't need to remove the hood to use it, this cap is a little samaller and clips neatly in the hood while fitted to the camera, easy to remove without taking the hood off.
Old April 15th, 2004, 07:30 PM   #5
Outer Circle
That's what I meant as well. All my caps fit onto the filter with the hood on the cam.
Old April 16th, 2004, 10:35 PM   #6
On the PDX10 I can't get the smaller cap to work in the larger lens shade. We have 2 for the PDX10. The standard one is nice but the larger one is better, even in everyday use.
The larger lens shade for the PDX10 has nothing for the lens cap to grab. In fact, in the larger shade, as it is bayonet mounted (thanks Sony) there are no threads at all. I can't even put a UV filter on it as the hole is meant to allow adding accesory lenses to the actual lens itself and not the hood.
Know what I am saying here. It's a bit hard to explain, and an odd setup too.
Sean
  You are here: DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony TRV950 / PDX10 Companion
