Will these batteries work with the PDX10? at DVinfo.net
Go Back   DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony TRV950 / PDX10 Companion
...plus TRV900, PD100A and other Sony DV camcorders.
Old January 5th, 2004, 03:57 AM   #1
These batteries are aftermarket, by Digicom, for Sony Camcorders. There are two in question:
#1) Digicom Replacement Battery For Sony Same As FM70
* Rechargeable Lithium-Ion battery pack for DCR-TRV8 and DCR-TRV10
* Built-in microprocessor accurately calculates remaining battery life in minutes
* 7.2V, 17.0Wh with no Memory Effect
* Up to 5 hours of continuous recording time
#2) Digicom FM50 Battery for Sony Digital Cameras
* Rechargeable Lithium-Ion battery pack for DCR-TRV8 and DCR-TRV10, DSC-S30, DSC-S50, DSC-S70
* 7.2V, 8.5 Wh with no Memory Effect
* Up to 3 hours of recording time
Links are:
http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=469526&Sku=D135-1114&CatId=131
http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=469527&Sku=D135-1112&CatId=131
It doesn't list the PDX10, nor a bunch of other cameras, so I thought I'd ask here. Perhaps the specs for the batteries don't match/aren't good for the PDX10?
Ronald Lee is offline   Reply With Quote
Old January 5th, 2004, 04:11 AM   #2
Maybe I should ask, which batteries work with the PDX10.
The FM50 and the FM70?
There are always a bunch of them on ebay.....
Old January 5th, 2004, 10:38 AM   #3
Ronald, I know they cost more but I would personally stick with the real Sony Infolithium batteries. The model numbers you mention don't sound familiar. I'd suggest you consider the Sony NP-QM91 which is the largest you can put on a PDX-10. Unfortunately it doesn't have the stamina of a NPF-960 on the PD-150 (which can last 8 hours), but I've gotten 4 hours with the QM91 on my PDX-10.
I'd be very careful about 3rd party batteries on the Sony cameras, you can read about lots of third party battery problems on the PD-150, and recently someone discovered that the PD-170 refuses to work at all with 3rd party batteries that were fine in the PD-170. To me it just isn't worth screwing around to save some relatively modest bucks.
The NP-QM91 lists for about $110 at B&H: http://www.bhphotovideo.com/bnh/cont...=275105&is=REG
  You are here: DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony TRV950 / PDX10 Companion
