I just bought Sony Dcr-Pc330 (Some Questions) - Page 2 at DVinfo.net
Go Back   DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony TRV950 / PDX10 Companion
...plus TRV900, PD100A and other Sony DV camcorders.
Old December 26th, 2003, 04:14 PM   #16
Tom, thanks for the info on the PDX10 and your explanation of how the latest cams spare some of the CCD for image stabilzation and high resolution 16:9. That makes a lot of sense.
BTW - I found this link on vibrating gyroscopes for image stabilzation (IS) and it sounds a lot like the IS on my Canon 28-135mm camera lens. Is this the same technology on the PDX10?
http://www.canon.com/technology/deta...correct_shift/
Tommy Haupfear is offline   Reply With Quote
Old December 27th, 2003, 11:03 AM   #17
I haven't visited the link yet, but yes - Canon's still camera lenses use the same vibrating element principle as Sony use with the 950. The system is working continuously, such that if you take a hand-held picture at 1/15th sec, say, then the OIS 'wipes' the image into the same spot on the film plane while the shutter's open. Ergo: less camera movement blur (but the same subject movement blur of course).
tom.
  You are here: DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony TRV950 / PDX10 Companion
