PDX-10 'Upgrade'? at DVinfo.net
Go Back   DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony TRV950 / PDX10 Companion
...plus TRV900, PD100A and other Sony DV camcorders.
Old October 1st, 2003, 09:26 PM   #1
PDX-10 'Upgrade'?
Hi,
by now most of us will have seen the announcement of the Pd-150 replacement - the PD-170. Nothing revolutionary, just some minor improvements and bug fixes. Can we expect the same for the pdx-10? Anybody heard anything or is the pdx-10 too recent a model to warrant any such move by Sony?
thanks,
DW.
David Warrilow is offline   Reply With Quote
Old October 1st, 2003, 11:33 PM   #2
Barry Wan Kenobi
Sony has made incremental improvements to their cameras in the past. The DSR200 spawned a DSR200A, the PD100 saw a PD100A, and now the PD150 has seen a PD170 (although the upgrades in PD150 to PD170 are much more significant than the minor modifications made to the DSR200 and PD100). So maybe there will be a PDX10A, but it'll probably be quite a while before any changes may be made.
Old October 4th, 2003, 11:34 AM   #3
But what would you guys look for if you upgraded the PDX-10 to a 10A? What needs fixing?
Tell you what I'd like to see on this semi-pro camcorder. A switchable ND filter, apertures in the viewfinder as you shoot, bigger NPF batteries, a six bladed diaphragm and a decent wide-angle converter included.
Well fancy that - I've described the previous PD100.
tom.
Old October 4th, 2003, 01:54 PM   #4
Contributor
More for the wishlist
Better low light sensitivity, a reflective mode display like the one on the PD170 and some previous Sony digicams, real switchable setup, less info so you can actually see what you are recording in the LCD and BWVF, more brightness control for the BWVF, locked audio when in DV-SP mode, switchable letterboxed output option, seperate audio channel switchable NR, 4 audio channel recording mode, real proscan, more exposure steps (like PD170), less vertical smear... oh and HDV video mode :-)
Ignacio Rodríguez in the third world. @micronauta on Twitter. Main hardware: brain, eyes, hands.
Ignacio Rodriguez is offline   Reply
  You are here: DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony TRV950 / PDX10 Companion
