950 16:9 vs 4:3 rendered as 16:9 at DVinfo.net
Go Back   DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony TRV950 / PDX10 Companion
...plus TRV900, PD100A and other Sony DV camcorders.
Old August 12th, 2003, 03:17 AM   #1
If I start shooting 16:9 on my 950 what would be the difference between that footage and what I shoot on 4:3, if they are both used in the same 16:9 project?
(Edit: seems tags don't work in the subject field)
Tor Salomonsen is offline   Reply With Quote
Old August 13th, 2003, 08:58 AM   #2
i'm not 100% sure, but i think there will not be any quality loss, 950 makes 16:9 picture by cutting down upper and lower part of 4:3 image anyway. It can depend on your edit program, how it makes picture cropping. Yeah, and time spent for rendering.
regs, Margus
Margus Kivilaan is offline   Reply With Quote
Old August 13th, 2003, 11:45 AM   #3
I use Vegas, which is great for cropping. But if you are right, rendering 4:3 footage as 16:9 and shooting 16:9 (on the same 950) and render as 16:9 will amount to the same: the footage is being chopped top and bottom.
Actually it will be better to shoot 4:3 because I can fine-tune the chop (adjust up or down) plus I can use the footage as 4:3 unreduced. Going the other way, shooting 16:9 and render as 4:3 will give me reduction twice, if you are right.
Can anyone confirm this, please?
  You are here: DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony TRV950 / PDX10 Companion
