PDX-10 vs. PD-150
get the PDX-10 and save for an Ikegami, or get the PD-150 and beef it up with all the glitter accesories?....
how close are these two cameras? |
Hello,
probably the single biggest difference (besides physical size) is low light performance.. the PDP-150 will be better in low light.. no doubt.. PDP-150 has bigger ccd's, I believe the pdx-10 is true 16:9 where I believe the 150 may not be true.. (could be wrong here, but i think not) mike |
Mike you are correct.
PDx10 is true 16:9, but the PD150 is not. I also like the size of the PDx10. You can film people more naturally because you are not so obvious. Also the audio gun mount on the PDx10 is detachable (not on the PD150) and you can use the other onboard microphone(just below the lense) of the PDX10 if you want the camera to be 'smaller' Regards P
Sony PDX10 by 2, DRS-11, Dual G5, FCX, DVDSP and Logic Plat. www.VarsityMusicVideo.com |
