Filter for reducing vertical smear? at DVinfo.net
Go Back   DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony TRV950 / PDX10 Companion
...plus TRV900, PD100A and other Sony DV camcorders.
Old June 6th, 2003, 03:48 PM   #1
Could a pola or grating filter be used to minimize the vertical smear on bright light sources?
Brandt Wilson is offline   Reply With Quote
Old June 6th, 2003, 08:15 PM   #2
From what I've seen on the PDX-10, there is a certain contrast threshold at which the smear becomes objectionable with a bright point light source. Not sure how one could change that with a filter. For example, I have a video of a sunset. It's fine while the sun is behind some thin clouds. But as they slowly move away a vertical line becomes visible. It isn't objectionable at first, in fact I like the effect. But as the cloud fully passes the sun the smear becomes an opaque white line, which looks bad.
Old June 7th, 2003, 02:28 AM   #3
I found this article:
Smear in CCD-sensors
Jan
___________
Jan Roovers
www.jtv.be
Jan Roovers is offline   Reply With Quote
Old June 8th, 2003, 01:16 PM   #4
if you mean optical filter then the answer is no
however there is an nle filter which is a godsend
get video finesse from synthetic aperture site, amongst the suite is a nice little filter called 'sa dropout'. it was designed to remove the white horizontal streaks from analog footage but it can be made to work in the vertical direction
if your nle is premier plugin compatible heres what you do
1 create a project 720x720
2 get your affected footage into this project and maintain aspect ratio
3 rotate the footage 90 degrees
4 apply sa dropout filter (tweak the sliders until the lines disappear)
5 rotate the footage -90 degrees
(3,4 &5 are done in one step by stacking the filters)
6 crop and render out to 720x480 or 720x576 dv codified
hey presto - no white lines!!
John Jay
Beware ***PLUGGER-BYTES***
John Jay is offline   Reply With Quote
Old June 8th, 2003, 08:32 PM   #5
video finesse
john,
this sounds pretty incredible. How effective is it at restoring a clean image where the vertical smear was?
Old June 9th, 2003, 06:54 PM   #6
Brandt,
what can i say apart from it works on removing those thin white vertical lines
try it
John Jay
Old June 10th, 2003, 04:02 PM   #7
Does anyone have any links to pdx10 footage displaying the vertical smear problem? I've noticed it in several still images but not video.
For example, on Jan Roovers' website (www.jtv.be), there is one video (Snow on the Sengel) where the only light is from streetlamps. I didn't notice any vertical smear (just wondering, having a PAL rather than NTSC camera wouldn't make any difference here, would it?).
What does vertical smear look like on video? Does the white line disappear and reappear as you pan sideways or is it there constantly?
Steve Pierce is offline   Reply With Quote
Old June 10th, 2003, 08:49 PM   #8
Steve,
I've uploaded a short example of a sunset which shows the problem. The sun drops below the clouds and gets brighter. At first it doesn't look bad, sort of a star filter effect. But it reaches a certain threshold where it turns into an opaque vertical bar. Note that this is a pretty extreme test however, shooting directly into the sun.
The video is compressed with sorenson 3 at 428x240 (scaled with Quicktime pro into the 16:9 aspect ratio). It has been reduced to 8 fps, and also sped up by 800% in FCP. It's a 1.7MB file which runs for about 18 seconds (also note the time lapse jet that leaves a vapor trail on the right side of the image right at the end :-)
http://www.greenmist.com/pdx10/smear
  You are here: DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony HDV and DV Camera Systems > Sony TRV950 / PDX10 Companion
