#106 |
You say the GL2 lacks progressive scan, but so too does the TRV950. Another loss in the move from TRV900.
#107 | |
Outer Circle
#108 | |
#109 |
This is a bit off topic, but the GL2 brochure states that "the GL2 includes a 16:9 recording mode, which applies an electronic anamorphic stretch..."
Is that simiilar to the capability of the pdx10? |
#110 | |||
Outer Circle
#111 |
Frank is on the mark here. The bottom line is you will not be all to happy with either of these camcorders and should look at cam's with a minimum of 1/3"CCD's due to your subject matter.
KennJ
KennJ |
#112 | |
Here is an illustration of how the PDX10 achieves its quality 16:9 http://img.villagephotos.com/p/2003-5/74415/PDX10.jpg Here is a great link on how camcorders achieve 16:9 either by letterbox or an anamorphic squeeze. http://www.maxent.org/video/16x9.html |
#113 |
TRV950 not recognized by iMovie or FCP
I just purchased a brand new TRV950. I connected it to my mac via ilink cable and my computer does not recognize the camera.
(I have a PD100 that works perfectly w/the cable and my computer) I went to the Apple store and to B&H and neither place could get the computer to recognized the camera. Has anyone else had problems with this? Is the iLink port broken on my camera or has Sony made it so the Mac video editing software no longer works. Before I called Sony, I wanted to put this out and see if anyone has any suggestions. Thanks. |
#114 |
Sure sounds like a camera problem; you did the correct tests and found the same computer could recognize another camera using the same cable, and another computer couldn't recognize the camera.
There are plenty of people using the TRV-950 and its sibling the PDX-10 with FCP on the Mac. Does everything else work properly with the camera? Have you tried pressing the RESET button (on the PDX-10 it's under the LCD screen next to the zebra switch)? |
#115 |
You may also want to try checking out the iMovie discussion forums, where the issue of various cams not being recognized by iMovie comes up: apple/discussions/iMovie. Sometimes it actually depends on at what point you turn on or attach the cam; seems to vary from cam to cam, believe it or not.
#116 |
"downgrade" from PD150 to TRV950
Hello,
I'm looking to sell my PD150 which I bought for a film project that is since completed. I find the PD150 too bulky and conspicuous to use on a regular basis. I'm interested in hearing opinions comparing the two cameras, other then the obvious differences of no timecode or XLR inputs. Also, is there an hours meter on the 950 like there is on the PD150, I'm thinking about buying used. Thanks for any advice. Jeff |
#117 |
Hello,
Myabe take a look at the PDX-10 also.. You will then have XLR inputs, 16:9 ,DVCAM and a very nice camera in a small package.. Mike M. |
#118 |
I'd second Mike's comments. The PDX-10 has all those features that I'm sure you've come to like on the PD-150. I don't think the 950 will have an hour meter but the PDX-10 does and you can set timecode. The XLR box is removable for those times you want to be inconspicuous. but it still records through builtin mikes like the 950.
#119 |
Thanks for the feedback. So, my next question is: When buying a used camera what is a generally accepted amount of hours. I assume that "taoe run" hours are the most important. Is that correct?
#120 |
I agree that the move from the 150 to the 950 will be a big backwards step, and that the PDX10 is a more logical move. The 950 doesn't have an hours meter, no. Tape run hours are one thing, but in the engineering world of tape transport, keeping running is a simple operation. It's the lacing, unlacing, loading, unloading that demand so much of a mechanical system. It's a chain of events that has to be set into synchronous motion.
Moving to a 950 will make you wonder where all your wide-angle coverage has gone, as well as all the light. Nice side-screen though, with clever party-pieces like touch operation. It's three menus deep even on the side-screen! tom. |
