Sony RX100 VI with 24-300mm Zoom? at DVinfo.net
Go Back   DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony RX CyberShots and CX Series Camcorders
Pro quality results from Sony consumer grade equipment.
Old September 27th, 2018, 04:39 PM   #1
Sony's CIZ enables the zoom range to be extended beyond the optical limit to about 300mm at the long end. This is not digital zoom, but 'clear image zoom', which uses AI to make up pixels cleverly.
Is it any good? Only you can judge. Here is a 4K test video that starts each scene with optical zoom only at 200mm and then invokes CIZ from the same place. The last two clips with the cardinal are both CIZ. Birds are good subjects for this - lots of fine feather details and colors.
Mark Rosenzweig is offline   Reply
  You are here: DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony RX CyberShots and CX Series Camcorders
