RX100V - How Do You Clear a Memory Recall?? at DVinfo.net
Go Back   DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony RX CyberShots and CX Series Camcorders
Pro quality results from Sony consumer grade equipment.
Old March 8th, 2017, 09:50 AM   #1
I decided to change some manual settings therefore, I need to remove/clear a memory recall. In other words, I have a setting already in memory recall #1, how can I remove it so I can replace it with a different one? Can't find an answer in the manual. Thanks, Ray
Ray Paula is offline   Reply
  You are here: DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony RX CyberShots and CX Series Camcorders
