RX10 eyecup with sugru at DVinfo.net
Go Back   DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony RX CyberShots and CX Series Camcorders
Pro quality results from Sony consumer grade equipment.
Old November 11th, 2015, 10:30 PM   #1
In case anyone's been considering Sugru vs other eyecup hacks, I gave it a shot yesterday and it works great. It could stand to be softer (perhaps by stretching some fabric on it?), but it works, comes on and off easily, and doesn't get in the way of the LCD screen.
I used 4 of the little starter packs, which is $22 and includes 4 white ones too, which I didn't use. Next time I would get more black packs and make it even bigger.
Slavik Boyechko is offline   Reply With Quote
Old November 12th, 2015, 02:57 AM   #2
Re: RX10 eyecup with sugru
Thanks I will give this a try
Phil Stanley
Phil Stanley is offline   Reply With Quote
Old November 12th, 2015, 07:05 PM   #3
Make sure to put dishwashing soap over the RX10 eyepiece first, so the Sugru doesn't stick to it.
Old January 5th, 2016, 04:57 PM   #4
Hi Slavic
Sent email with questions reply if you received it.
Luis
Luis A. Diaz is offline   Reply
  You are here: DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony RX CyberShots and CX Series Camcorders
