New Clips Compilation RX-10M2 at DVinfo.net
Go Back   DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony RX CyberShots and CX Series Camcorders
Pro quality results from Sony consumer grade equipment.
Old September 2nd, 2015, 03:33 PM   #1
HI ALL :
My initial experience with the RX-10M2
THANK YOU
LUIDOLY
Luis A. Diaz is offline   Reply With Quote
Old September 2nd, 2015, 04:01 PM   #2
Re: New Clips Compilation RX-10M2
Good stuff Luis
Got this cam for personal use but used it at a wedding for couple clips. It is really growing on me. But whatever I do I prefer auto iso for some reason the camera works better?
Neutral setting 0 0 0 best so far. Slog-2 good but so hard to control with trying to over exposure with the back scroll wheel. Canon cameras with the meter bar, you know to stop down or up but rx10 only flashes and to get correct exposure means it just stops flashing? Steve
Old September 2nd, 2015, 05:01 PM   #3
Thanks Steve:
All clips were shot with auto ISO, I have very little experience with the S-Log setting but I know it can be used effectively to increase the Dynamic Range in post with color grading.
I will try that next, my main input is aperture priority and I am surprised at the little noise you have even at ISO 6400. Also the fact that the full HD XVAC-S AT 60P is a very good codec to use for full HD. I wish it would have Active Steady Shot in 4K, may be in an upcoming firmware upgrade.
THANKS
LUIDOLY
Old September 2nd, 2015, 05:18 PM   #4
Cheers buddy. The aperture mode is great and I use mostly the 2,8 aperture which gives a little bokeh. xvhc-s
At 50 p here UK is great. Stupid no steady shot in 4k.?? Good luck Steve
Old September 17th, 2015, 05:26 AM   #5
Contributor
Originally Posted by Luis A. Diaz View Post
Thanks Steve:
THANKS
LUIDOLY
Active steady shot crops off the edges and digitally stabilises the image. Can't do this in 4K mode. Not enough processing power I would think..
John Mitchell is offline   Reply
  You are here: DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony RX CyberShots and CX Series Camcorders
