RX10-II matches A7s in Dynamic Range?? at DVinfo.net
Go Back   DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony RX CyberShots and CX Series Camcorders
Pro quality results from Sony consumer grade equipment.
Old July 29th, 2015, 07:11 PM   #1
Just did a quick side by side with the RX10-II and the A7s.
Yes, we know the A7s destroys the RX10-II in low light and noise. But what about dynamic range?
I exposed the light to the right of both shots right at about 100 IRE. Using that as the standard we can then inspect how far down into the shadows both cameras can see.
Both cameras used their wonderful SLOG-2 compressed gamma curve.
Way to go RX10-II. It took on the A7s challenge very well!
Thanks Sony!
RX10-II matches A7s in Dynamic Range??-a7s-slog-2.jpg   RX10-II matches A7s in Dynamic Range??-rx10-ii-slog-2.jpg
Cliff Totten is offline   Reply
  You are here: DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony RX CyberShots and CX Series Camcorders
