how to get rid of histogram display after I take picture (RX100) at DVinfo.net
Go Back   DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony RX CyberShots and CX Series Camcorders
Pro quality results from Sony consumer grade equipment.
Old December 25th, 2014, 12:38 PM   #1
Hi there,
RX100 MIII. Great camera, but it's got me baffled. I somehow, by accidentally hitting a wrong button, have it so that after I take a picture, instead of seeing that photo on the display, I see a small version of the photo, surrounded by lots of graphs and charts, blueprints, schematics and histograms. Too much information that I don't need.
I've tried resetting my camera, but to no avail. Would someone kindly tell me how to fix this problem?
Thanks so much,
Malcolm
Malcolm Hamilton is offline   Reply With Quote
Old December 30th, 2014, 03:47 AM   #2
Re: how to get rid of histogram display after I take picture (RX100)
Hi Malcolm -
Hit the "DISP" (up portion of the rotating ring), it should cycle you through the multiple options.
If you want to get fancy and choose which display options you have available, "menu", the gear tab, select "2", DISP Button, and you'll have the option to set multiple display options for both the LCD and the VF... I've found it handy to set the options most used, and uncheck those which you don't feel you need!
Sorry I didn't notice the Q sooner, holidays and all that! The MIII is quite handy for all the family get-together pix!
Dave Blackhurst is offline   Reply
  You are here: DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony RX CyberShots and CX Series Camcorders
