HDR-CX900 RAW file upload at DVinfo.net
Go Back   DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony RX CyberShots and CX Series Camcorders
Pro quality results from Sony consumer grade equipment.
Old September 28th, 2014, 01:35 AM   #1
I shot a film festival with my CX900, with 16x9 Inc's EXII 0.8x wide angle adaptor. I uploaded a selection of stitched together raw XAVC S 1080 30p camera clips for anyone interested in seeing how these little 1" sensor cameras perform when pointed at stars. The camera performed so well, and the picture quality was so exceptional, that I believe I will be plunking down $2300 for an X70 as soon as B&H's website comes back from Saturday holiday. :-)
http://1drv.ms/1pz9ewD
Paul
Old September 28th, 2014, 07:48 AM   #2
Re: HDR-CX900 RAW file upload
Were the WB adjustments as per your previous post?
Bruce Dempsey is offline   Reply With Quote
Old September 28th, 2014, 12:10 PM   #3
I used push to white constantly. The lighting was changing and inconsistent the whole time.
Also, the last 4 clips were shot with Cinamatone ON.....thought I would give it a try. I don't really like how it looked......perhaps the slightly off colors were amplified by that settings chroma boost.
Paul
Old September 28th, 2014, 12:32 PM   #4
push to white means you have a white card or somethingm to point at
Old September 28th, 2014, 01:51 PM   #5
That is correct, and the push to white needs no option adjustments for correction, only if you want to in camera color grade. I did have the option off-sets for the presets and for the manual kelvin, and may have switched to those for scenes like all outdoor stuff.
Paul
Paul Anderegg is offline   Reply
  You are here: DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony RX CyberShots and CX Series Camcorders
