#196 |
Re: Sony RX10 user experience thread
Well, I cant get over the quality of the video image I'm getting from the RX10, its unbelievable.
I have never used a DSLR before and am trying to get used to the different settings it provides. I've read all of the posts (again) in this thread and find it all very informative, thanks to Noa for starting it off. I'm trying to get used to using full manual but its not easy :) I only have it a few days so a bit of practice needed yet. I will use it at my weddings but won't do until I get more familiar with settings and buttons. I got myself extra batteries, led screen protector, two SanDisk 64GB SDXC UHS-I/U3 Cards BTW, so good to go. Thanks for the help and if you can advice me in some of the setting or presets, please do :) |
#197 |
The only thing I dislike is how easily highlights can clip on this camera, it's dynamic range is not that impressive and you need to have your exposure spot on.
#198 |
Thanks Noa, i"ll watch out for that.
#199 |
I continue to be amazed and delighted how good the video quality is I get with the RX10, so much so that I really see little point in 'upgrading' to 4k (for viewing on my 24 inch Dell monitor).
I generally find the vivid mode excellent in situations where the scene is a bit flat with little to no blacks and the landscape mode about right when I want to preserve blacks. I generally employ plus 2 sharpening. I have no problem with highlight clipping in fact I find I get remarkably good detail in puffy white clouds with ease. I should add that I have no problem with blown highlights here and there, and for that matter I see that happening in commercial films too. Perhaps the dynamic range is also limited by the viewing equipment. Actually I have never had anyone notice and comment on blown highlights when viewing my output and I believe we fuss over this dynamic range thing overly much. I would go so far as to say that some footage I have viewed where the editor has gone out of his/her way to preserve dynamic range looks unnatural, a bit flat and lifeless. In my experience the RX10 is a great video camera and it delivers excellent photographs too. A little more reach would be nice. |
#200 |
Thanks John.
#201 |
The highlights do blow out pretty quick, what I do is set my exposure comp to -0.3. I find this helps.
#203 |
Thanks Simon and John.
#204 |
I'm having so much fun with this camera, love it. My main camera is a PMW500, it produces beautiful images but… the RX10 for its size and what it does is great.
The thing I dig is, fixed lens, one inch sensor (I don't need full frame) variable frame rates and it take a great still image, for me using this camera in the style as a video journalist it's just about perfect. If Sony upgraded this camera? and put 4:2:2: plus the better dynamic range it's a winner. Sony really made a great camera here and one that I feel could be used in many productions. |
#205 | |
Looking forward to getting to know it better. |
#206 |
Happy with the images I'm getting at the mo, considering I never used a dslr before but would like to know please, what's the max ISO setting you should use for indoors or outside? Is there a rule of thumb ?
Thanks. |
#207 |
ISO 3200 is about the limit and even this there is noise. I guess it's about the shoot, if I need the shot then I'll crank the iso. I would say ISO 1600 is about the max for a clean image, I could be wrong.
#208 |
Thank you Simon, I will keep that in mind.
The weather is beautiful today, so, a good excuse to give it another outing. |
#209 |
What benefit will I get from a SanDisk Extreme PRO card in my RX10 compared to SanDisk Extreme version?
SanDisk Extreme PRO 64GB SDXC UHS-I/U3 Memory Card up to 95MB/s Read FFP (SDSDXPA-064G-FFP): Amazon.co.uk: Computers & Accessories SanDisk SDSDXN-064G-FFP Extreme SDXC UHS-I Class 10 U3 Memory Card up to 60 MB/s read - 64 GB: Amazon.co.uk: Computers & Accessories |
#210 |
As long as they are both U3, they should work fine. That's the key for XAVCS high bitrate (for the moment at least, next year if we see 4K/60p and higher bitrates, they may or may not be "fast enough").
The difference will come in read/write/transfer speeds - which may come into play if you're doing burst stills with RAW or RAW+JPEG. The faster card can write quicker, and clear the cameras buffer faster when doing this sort of data intensive shooting. If you want to get 10 shot bursts and reasonable recycle times (camera is ready to shoot another burst/shot), it takes FAST cards. I did some tests when dealing with a bozo buyer of an RX100 - complained the camera was "broken" when it wouldn't write RAW+JPEG bursts to the rated 10 shots and would "freeze" for up to a minute while writing from the buffer... on a CLASS 4 CARD!!!! What I found was a fast card (at that time) would shoot the full 10 burst, and recycle in around 10 seconds, a "slow" card would max at a burst of 8, and take up to a minute to recycle... I now am a little more conscious of the "details" on a card - they vary WIDELY, even within the same "class" (most are now class 10). For video, you probably won't see ANY difference as long as it's U3 rated (been buying a few, and the 60MB/s is the lowest I've seen on a U3 card, most seem to be 95 and above (although some seen to be rated differently for read vs. write). Presuming it's a genuine card and not a HK/China knockoff, you should be "OK" for VIDEO. The other place you MAY see a difference is when downloading your clips/stills - a faster card SHOULD in theory result in faster dumping of your data to your computer. This could be affected by your USB port (USB 3 being faster), and your HDD/SSD. An older computer may have other bottlenecks... Generally speaking, "faster is better", but given that faster costs more $, sometimes there is "fast enough" in practical terms. I've been trying to pick up the largest/fastest SDXC U3 cards I can find, replacing the "fast enough" SDXC U1 that were just fine before the higher bitrate XAVCS firmware updates... fortunately I have someone who is buying most of the U1 cards and appreciating the great deals... on the ones I JUST bought not so long ago... |
