nex 700 with fujinon lens at DVinfo.net
Sony NXCAM NEX-FS700 CineAlta
Old January 3rd, 2015, 03:44 PM   #1
Hi guys, i'm about to buy a camera and my first choice goes with sony nex 700, but i have several canon dslr lens and 2 ENG lens, one fujinon and one canon kt 14.4 that i use with my JVC PROHD 700, can i use them with the sony camera just changing the adaptor, will the zoom of the ENG lens work normaly, what adaptor should i by?
Thank you people
Best regards and happy new year
Luis Santos
Luis Ventura is offline   Reply With Quote
Old January 3rd, 2015, 10:44 PM   #2
Re: nex 700 with fujinon lens
If you mean the NEX FS700 then yes you can use a B4 lens with an adapter but it will have to be a 2/3" lens with a 2 x doubler. Check out Alistair Chapman's video here:
Chris Young
CYV Productions
Sydney
Old January 5th, 2015, 05:32 PM   #3
Thank you Chris i will check on that.
Best regards
Luís
Old January 6th, 2015, 05:20 AM   #4
If you want to have a look at what an MTF B4 adapter can do check out my first test with one on an FS700.
Chris Young
CYV Productions
Sydney
Old January 7th, 2015, 08:01 PM   #5
I have a Canon lens on my FS700. It is SD glass, but is pretty sharp at ~F6 and higher. I have the lens' 2x doubler engaged. It is attached to a B4->EF adapter, then to a Kenko 1.4x tele-extender to prevent vignetting, and finally to a Metabones EF->Sony E Smart adapter functioning only as a 'dumb' adapter.
nex 700 with fujinon lens-full-rig1.jpg   nex 700 with fujinon lens-full-rig7.jpg
www.CinemActionFilms.com
Steven Reid is offline   Reply With Quote
Old January 8th, 2015, 06:56 AM   #6
The OP mentioned JVC GM700 lenses. Are you using them on the GM700 with crop factor for your sensor? (AKA are you using true 2/3'' lenses?) If there's no crop factor and they were designed for your GM700, it will not work. At full wide, there won't be enough coverage to cover the entire sensor compared to a 2/3'' lens.
Mind giving the specifics of both lenses? The one that came with your GM700 probably will not work for this purpose.
Jack Zhang is offline   Reply
