Is it possible to break the E mount? at DVinfo.net
Sony NXCAM NEX-FS700 CineAlta
Old September 2nd, 2014, 09:59 PM   #1
A bit of a daft question I know as the answer is obvious. But let me finish ...
I purchased a FD to NEX adapter ... different brands. Some will fit easily, others fit on one camera but not the other EVEN THOUGH ALL THE CAMERAS ARE E-MOUNT.
So in my case, I had a Fotga FD to NEX adapter which had a fantastic solid fit to my FS700, NEX 7 and even fit my friends VG20/VG10 very nice.
Now I have another adapter which doesn't fit so well on my NEX 7 ... I stupidly applied more pressure than I should trying to fit it on. Can't see any damage but it just occured to me that I may have bent some thing on the mount with that sort of pressure that I applied ...
It got me wondering has any one ever broken their e-mount fitting poorly manufactured dumb adapters?
Old September 2nd, 2014, 10:10 PM   #2
Re: Is it possible to break the E mount?
Hey James
I have a el-cheapo Fotga too and originally it wouldn't fit my camera ..the flanges on the adapter were correctly cast but they powder coat the aluminium so the flanges end up too think .. I just used my wife's emery board to remove the black powder coat and it fits both EA-50's perfectly ...it was just like yours and VERY tight ....I doubt whether have broken anything on the camera ..those machined mounts are super strong!! Check it with an e_mount lens ..if the lens doesn't fall off then all is OK ... I would seriously reduce the thickness of the Fotga flanges so it is a smooth fit on the camera and not too tight ...!!
Chris
Old September 3rd, 2014, 06:17 AM   #3
Hi Chris
All my other lenses fit perfectly fine with no movement what so ever. Guess i'm just being paranoid.
Old September 3rd, 2014, 06:43 AM   #4
Hey James
My pricey Novoflex adapter is actually a tiny bit sloppy and you have to be careful it doesn't move. I think I prefer the $15 Fotga although I had to use the Emery board a bit, I was able to get what I think is a perfect fit ..tight enough not to move on it's own but not too tight as to damage the e-mount or lens mounts.
Yep, I very much doubt whether you could physically break the e-mount on the camera side ..if anything went bang it would be the little flanges on the adapter so I'm sure you can breathe easy!
Chris
Old September 4th, 2014, 12:49 PM   #5
You say that Chris but i've read stories of heavy lenses (70-200 f2.8 L lenses) breaking the mount off a Canon DSLR so I don't think these mounts are as bullet proof as they seem.
James Manford is offline   Reply
