When in SQ mode camera shows flashing FMU at DVinfo.net
Sony NXCAM NEX-FS700 CineAlta
Old July 2nd, 2014, 03:49 AM   #1
Hi
I've had a problem today trying to record slomo to an SDHC card via the SQ button. For some reason the camera has FMU flashing with a line through it. There is no FMU installed, so just wondering why I can't record to the SDHC card.
Regards
Mal
Digibeta Video,
Sydney AUstralia
XDCAMeraman, Sydney, Australia
digibeta.com.au xdcam.com.au
Mal Hamilton is offline   Reply With Quote
Old July 3rd, 2014, 03:48 AM   #2
Re: When in SQ mode camera shows flashing FMU
Mal ~
Going from memory, go to MENU and select the double headed arrow which is the REC/OUT SET menu then go down to and select MEDIA SELECT and under that menu is should be set to MEMORY CARD. Me thinks it's set to FMU :) From memory a warning will flash if no FMU is installed and that menu is set to FMU.
If that's not the case I'll have to look at the camera.
Chris Young
CYV Productions
Sydney
Old July 6th, 2014, 11:47 PM   #3
Thanks Chris
I think the camera must have defaulted to the FMU when I forgot to switch off.
All good now.
Cheers
Mal
