Are theri options for control (zoom rocker/Rec) at DVinfo.net
Sony NXCAM NEX-FS700 CineAlta
Old December 27th, 2013, 01:14 AM   #1
For the FS700 - I'm wondering if there are options for a seperate control to trigger the recording on the camera, say if its on a rig and the current button placement isn't ideal. A bonus would be if I can still control the zoom rocker, but I'm thinking that is likely more proprietary.
Thanks.
Independent Filmmaker in Canada's Capital
Graeme Hay is offline   Reply With Quote
Old December 27th, 2013, 08:39 AM   #2
Re: Are there options for control (zoom rocker/Rec)
There is quite a bit of slack on the cable which connects the zoom rocker handle to the camera body. I purchased a handle extension for my 700 from Olaf at Westside AV so mine sits forward about 6" from standard. If you wanted to extend even further perhaps on a jib, I'm pretty sure you can buy inexpensive extensions as the cable is not proprietary.
mb
Mark Bolding is offline   Reply
