Seeing FS700 SDI and HDMI on Marshall Monitors at DVinfo.net
Sony NXCAM NEX-FS700 CineAlta
Old March 31st, 2013, 10:42 AM   #1
Hi,
I am only able to see the component output from my FS700 on my Marshall monitor. The monitor won't read the HDMI or SDI outputs (or maybe even the camera isn't sending the video which makes less sense). I am hoping that there is a setting somewhere I can change on either unit to fix this. If you have any suggestions, please send along.
I have a Marshall V-LCD70XBH-HDMIPT.
Peter Walsh is offline   Reply With Quote
Old April 1st, 2013, 07:55 AM   #2
Sponsor: Westside AV
Re: Seeing FS700 SDI and HDMI on Marshall Monitors
Set output to 60i or 50i on the 700.
This does not effect recording, but makes it possible for the many monitors to see the signal.
Old April 1st, 2013, 04:00 PM   #3
Hello Olaf,
Thank you. Can you be a little more specific. Where/what menu on the camera is this?
Old April 1st, 2013, 05:38 PM   #4
Hi Pete Its in the VIDEO OUTPUT second section down when you press menu on the camera mine is set to 1080I/576I set it to that and it should be fine (probably so long as your on pal camera system i did'nt look were you are based) Wilf.
Wilf Davies is offline   Reply With Quote
Old April 2nd, 2013, 12:15 PM   #5
Hi
Thanks to both of you for your replies. I thought this was the menu section but wanted to double check. It appears my Marshall does not like the FS700.
